Good morning!!!!
   / Good morning!!!! #118,761
The install of Linux on the USB stick got done about 1230. It installed a boot manager on his pc which I didn’t expect. This is a network course for a business major, not a CS major. I can’t believe they have them installing and using linux for this course, even though it’s great experience.
When I want to use Linux on my pc I just use a bootable cd, no boot manager involved. Makes it simpler. For work I just use a dedicated pc set up only with Linux, that’s even better.
Supposed to go to mother in laws next weekend to spread a load of topsoil on her yard where it’s washed out in places to reseed. Hope that rain stays away.
   / Good morning!!!! #118,762
Drew, I always spotted the stern lights first, then picked up on the nav/ bow lights as I got closer. Loved night boating. I had my only real boat crash at night though, tide was record low, that Donzi Z25 was going too fast and I was too deep in the Southern Comfort bottle, hit a stump on the starboard stern and flipped it upside down into the marsh mud. My two buddies couldn’t swim but the landed in the mud unharmed, my tee shirt was pinned to the mud by the wrap around part of the windshield. They dug me out and I only got a concussion and bruised ribs, along with a still visible crease below my right eye. Lucky we weren’t all three killed.
Night boating is fun, drunk boating is stupid.
   / Good morning!!!! #118,763
Good Morning!!!! 68F @ 5:00AM. Some clouds this morning will give way to generally sunny skies for the afternoon. Areas of smoke and haze are possible, reducing visibility at times. High 89F. Winds light and variable.
I suspect that smoke forecast is wildly optimistic. Yesterday visibility was down to about 100', and at times, even less. The good news is that the IR satellite map is showing no hotspots to the east, and more of the fire perimeter is cooling off as well. But we have another Red Flag Warning starting this morning, running to the end of the day, for a wind event and very low humidity. At last night's press conference, firefighters were optimistic that they will be able to hold the lines, but we were all cautioned to remain vigilant and be ready to evacuate if called to do so.
That same video had news that a long time neighborhood trouble maker had been arrested for being in an evacuated area, and he had stolen mail in his possession. The guy's way beyond three strikes, so hopefully they'll send him up for a good, long time. This was the one that ran the drug house my good neighbor subsequently bought and is currently remodeling, and that was caught stealing a hotrod out of Oroville and trying to tow it to said house. He did four or five years for that caper, and has been out less than a year.
Beautiful moon shot, Ron. I remember back when I could see the moon...
Hope the new place passes inspection, Drew, and the dentist doesn't beat up your mouth too badly.:hissyfit: Thanks for the air purifier info, but the RedNeck Geek's only real choice was a Dyson.:laughing: Should be here Friday.
Hope your ceiling painting doesn't turn into too much of a pain in the neck, Thomas. And that Dad and Boo continue to behave themselves.
What a pair, David!:laughing:
Blew out the filters on the Dyson vacuum, then ran it for an hour or so, but it didn't make a dent in the bad air inside. Put a new filter on the furnace/AC, Kyle, and ran the fan for a few hours. It brought the AQI down, but not out of hazardous levels. :crossfingers: I make it 'till Friday.
Ted, the pump is behind that control panel. I think I'd sell the firetruck before I'd tackle a pump rebuild.:(
Walking around outside yesterday, I kept coming across leaves like this. Looks like it's from a Bay tree, and it's brown and brittle, burnt almost to the point of charcoal. It was carried here on the high winds that also carried the fire on Tuesday night and Wednesday morning. It was one of the things I could hear hitting the glass sliding door in the bedroom. A little hotter and that leaf would have been an ember, and I don't even want to think about what that would have meant.
Yesterday the Sheriff lifted the Evacuation Warning for most of Oroville, so maybe today I'll get some mail. The Post Office has been closed since last Tuesday, and the mail is being held in Yuba City, an hour south of here.
The tachometer in the van became intermittent again on the last trip to town, so yesterday I pulled the instrument cluster again to see if I could do anything about it. The connector mates to the tach with four metal pins, and one of them came out last time I disconnected it. So this time I disassembled the tach to get at the circuit board, and found that all four pins had broken their solder joints. Got 'em resoldered, then put everything back together, only to find I'd bent the shaft the needle rides on. Not badly enough to keep it from working, but it is noticeable. I also found a way to hold the tach connector in place with a sheet metal screw instead of the zip ties I tried last time, and hope that's the end of that problem.
I was about to put the cluster back in the dash when I noticed that the fluid in the brake reservoir is getting brownish, so it needs changed. I'll do that today, hopefully in air that's a little better. AQI outside was back in the 600 range yesterday.
Did some reading about the alternator idiot light, and found a test or two for the alternator itself. The wires going to the LED in the dash look fine, none are rubbed through or loose. One side of the LED references a three legged voltage regulator, and I found a test for that, too. It's an aftermarket part, and that makes it a suspect in my book.
Hope everyone's week gets off to a good start!
   / Good morning!!!! #118,764
Good morning to all! Low of 52, high going to ?, I haven't watched the forecast, but I assume somewhere around 80.
Drew, I wish you luck that everything checks OK on your rental. It's great that you have a set of ears / eyes up there to make sure everything is good.... you don't need any surprises!
Rng, good to hear the fire close by is being held at bay..... those leaves being that close to ember status is a bit unnerving to say the least.
Ron, very good pic of the moon.
Yesterday, I was able to get all the yard tools organized and hung up in the garage.... now no more moving two string trimmers to get to the pole saw, or digging through a pile to get lopers on the bottom. Now they are easily accessible! Yea!
Moved a couple other things around, like my portable compressor and air tank.... they now live next to the big compressor. Put it up on a platform that is high enough that two floor jacks can slide under, making effective utilization of the space.
More of the same probably on the agenda today, also make a burn barrel.... burn restrictions have been temporarily lifted.
Everyone have a great day!
   / Good morning!!!! #118,765
57°F and partly cloudy this morning, going up to 82°. We may be looking at highs around 70° by the end of this week. Not gonna hate that.
I have no idea what happened to the weekend. Where does the time go?
I've been wearing cheaters to read for the last couple of years, Kyle. I just had a moment about a week ago where I was trying to read dimensions on a small 8.5 x 11 drawing print, and I was having to switch back and forth between the readers and my safety glasses. Decided to just get some bifocal safety glasses.
Nice that you're getting some serious help here with the fire truck, RNG. This place never ceases to amaze.
We had a serious infestation of fruit flies at work a couple weeks ago. In spite of thorough cleaning and making sure no one left anything in their waste baskets, they simply wouldn't go away. The owner of the company brought in some of those little fluid traps, and they mostly disappeared within about two days.
Great pics, Ron.
   / Good morning!!!! #118,766
Good Morning - was 50 going to 77 today-
Took out 5 of the 6 bigger stumps in my side yard - two that look like I can just flatten as they are old. a few that are pits that need to be filled in.
The last stump-that one is an oak and cut through about 6 roots, 3 with the sawzall-but BH would not even budge it-
After 2 hours cutting and hacking at that stump -decided to go aerate the various lawns with the lawn tractor, that went well and only took another hour or so.
Trying to figure out now if I want to keep hacking at the stump or do some kind of burn.
Patched up hole where tree fell in my planned trail and started putting down wood chips-will need more chips only had a few bucketfulls ready.
Drew - New Hope has changed a bit, Zadars is now Stella (restaurant/hotel) - Odettes is now a conference center and the center part of the old Odettes is now at the entrance to town. Logans in has expanded and is still building. the old mall is now a food court. But it still retains most of the town feel. Some artsy places, but less than there used to be. The book store is still there and a favorite haunt for us. The Mill playhouse has expanded their back deck but still looks like it did many years ago from the front. We were down their yesterday and the train was running , always nice to see the old engines go. One house we had looked at before we bought our current one had the tracks on the edge of their property and always put out decorations for the train people to see..
Stay safe and be well.
   / Good morning!!!! #118,767
Good Morning All.
Seems my new Kioti dealer has in stock ignition switches!!!!!
WOOT this might be an easy fix!
Be well all,
David
   / Good morning!!!! #118,768
3 cavities filled and mucho bucks later, I am left with a rubbery mouth but all is well.
Got email from old friend saying he and brother were going up to his cabin in the Catskills first week in October, near Arkville/Margaretville NY.
He bought the place in 1971 for a song, year we both got out of college. Been a while since I've been there, not this year but maybe next.
Would love to take rv up there and at least have a comfortable bed; the hideabed for guests is a torture chamber.
Found this old pic, Yamaha snowmobile goes way back, first one with heated grips, we were living large. When the snow was two feet deep up there, snowmobile only way to get up the one mile long bulldozed path to the cabin on side of mountain. Then it didn't seem to snow enough so sold
that sled in 1986 and bought the Honda Foreman 350. The Honda is still at the cabin, looks like new, well taken care of by my friend's very mechanical son and lives in its own shed. I gave it to them about ten years ago and they still use it to pull a cart to go fetch firewood.
Ahhh, back when I had hair...;)
when I zoomed in on the atv picture I went huh? looks like I had a cigarette in my hand, and I've never smoked. Looked more carefully and it's the line of my golf shirt collar...
lovely day out but guessing storms headed this way when cold front hits. Meanwhile it's a little breezy.
   / Good morning!!!! #118,769
64F and sunny @ 10:45, headed up to only 69F for a high today ... 80's back in the forecast in a couple of days though. Extended forecast looks dry ... at least at the moment.
On agenda for today:
Finish clean up of cut grass/weeds around culvert/ditch out front.
Finish clean up of east planting bed, prep two planting holes for rhododendrons.
Some pruning with Stihl polesaw.
Possibly start to set culvert pipes in dry creek bed for the path over to the pole barn.
No shortage of stuff to do.
Hope everyone has an enjoyable, productive, and safe day ... :thumbsup:
   / Good morning!!!! #118,770
First cup of coffee is cooling. 52ー with clear skies this morning. Heading to 68ー with lots of sun. 6 of us enjoyed GD birthday yesterday. Saw trees starting to change color on 25 mile trip north.
Neighbor has one maple (golden) that always seems to turn earlier than any of the other trees around here, noticed the other day that it's starting to show signs of making the move.
Caught a picture of moon before it is gone for a couple of weeks.
Nice.
RS, hope you get gardens done before winter sets in. ;)
I'll be done with whatever I'm going to do for the season long before December 21st ... ;)
Good luck with the painting.
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
New/Unused Excavator Brush Flail Mower (A57454)
New/Unused...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59575)
2018 INTERNATIONAL...
2015 Lincoln MKZ Sedan (A56859)
2015 Lincoln MKZ...
