Good morning!!!!
   / Good morning!!!! #113,181
78F more clouds than sun.
Painting all done for now until new storm door arrives been over 2 1/2 weeks...arrrr.
Haven't used pickup for couple days but the Mrs. has mention foul smell,open the door just about gag me :confused2: good couple hours air out did cab search...I did found cigar :)… check outside vent nothing all was left fan air filter box,getting to air filter means removing half glove compartment and patients is a must,found 2 field mice dead filter chew after good cleaning $20 for new filter putting every thing back together little over 2hours I enjoy that cigar I found. ;)
No plans for tonight other than numbing it.
Enjoy the evening all.
   / Good morning!!!! #113,182
Thanks for all condolences and prayers it means alot
   / Good morning!!!! #113,183
Thomas glad you found the source of the smell
You ought to see them come out of paver screed when heating up
   / Good morning!!!! #113,185
Had a mouse run out of my grill last time I fired it up.
   / Good morning!!!! #113,187
Nice wagon wheel.
Started the ceiling job. Moved bed out of way, vacuumed all the dust bunnies..sanded the tape job I did years ago when I took out the skylight, pulled some old tape out of another joint, retaped that seam and added mud to the patch area. Mud was too dry, so not a very good job, but it will sand out. Hopefully dry tomorrow so I can do it again.
Storm came thru little bit ago, got a good rain we needed. Might get another storm soon.
   / Good morning!!!! #113,188
"The Lancet announced today that it has retracted a highly cited study that suggested hydroxychloroquine may cause more harm than benefit in patients with COVID-19."
Two Journals Retract Studies on HCQ, Heart Disease in COVID-19
So now Hydroxychloroquine is OK in treating Covid19. ? The negative studies did not pass the test. It gets scary when medical and political cross the line. Two more reads.
Author of Two Retracted COVID-19 Studies Once Bemoaned Misconduct
Leading Journals Sound Alarm on COVID-19 Studies
   / Good morning!!!! #113,189
Successful day! Slow, hot, but productive. We got all the trim on the shed painted and second coated. Most of it all up high on the eaves and gables. I set up two scaffolds. So that made it a lot easier. Tomorrow will entail painting the siding to match the house. We are going out there early... high temp supposed to hit 98....
In between breaks out of the sun, I was able to spray the park bench opposite sides. They will be ready for assembly, but I still have to cut , route the edges, sand, and stain the slats.... that will not happen until next week sometime.
Did some takeout for dinner... just burgers and onion rings. Now going to relax and have a bowl of blueberry cheesecake swirl ice cream....
   / Good morning!!!! #113,190
Pretty good start on the garden today.
I had previously posted where I had tilled and then tested to learn how poor our soil. I did add dolomite lime to help with ph.
So I decided not to do a traditional row garden rather rather rows of small hills of compatible plants. Read of corn doing well in hills and
So laid out 3 rows, hills 4 ft apart. Added some triple 16.
Then I dumped about 5gal of garden soil over each spot.
A couple weeks ago I started some seed. Here is a corn start.
I was pretty impressed how well the roots developed.
So 10 hills with 3 each corn starts, 2 rows seeded with bush bean, 1 row zucchini and cucumber, 9 hills with 3 sections of sprouted potato (ash coated per Don) with tomato start in middle. 3 hills, 4 starts each Kai Choy, 6 hills squash starts and cucumber seed.
Still want to add a 3 compatible seed like carrots, radish, etc.
Need to add another row for my pepper starts, but they are behind so a few more days in starter.
Need to revisit things like cauliflower, eggplant, Brussel sprouts that didn’t germinate. Will also start a second corn crop.
Rooster Weathervane (A55853)
Rooster...
PJ TRI-AXLE GOOSENECK TRAILER (A52708)
PJ TRI-AXLE...
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2014 JCB 930 (A57148)
527 (A52708)
527 (A52708)
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A56435)
Mahindra 4550-4L...
