Good morning!!!!
   / Good morning!!!! #112,401
Randy, now your gonna make me find another landscaping project to do.... yours is looking real good! I bet you are glad you got that new little tractor!
   / Good morning!!!! #112,402
62F and partly cloudy @ 22:15.
Rain quit in time for me to get one of the hoses off and head for NAPA before they closed. A bit tricky though, as one end of the hose goes onto a fitting on a hard line which has fairly thin walls and would be easily bent. The reason why it was tricky is that four lines all terminate in roughly the same place, and there is just not much room to get a wrench on the hard line to apply counter-force while torquing on the hose fitting in the opposite direction. But somehow I managed ... :D
As I was heading out of the driveway I ran into my neighbor who I had called about the spanner wrench coming down the drive. He'd tried to return my call but wasn't able to get through so he came on down ... so we headed down to the house so he could put eyes on the cylinders.
He does have two of the adjustable spanner wrenches: honkin' large and small(er) ... but didn't think the pin on the smaller one would even be small enough. Which was kind of what I figured.
He also has experience replacing cylinder seals - including urethane ones - which he says are a complete #$%@! to do ... at any rate he offered his help if I feel I need it. He'll probably be getting a call ... :laughing:
Of course that all took time and by the time he left it was about 5 minutes before 17:00 (time the local NAPA closes) so that trip went out the window.
Perhaps just as well ... while we were standing around jaw-jacking I noticed the hose I had gotten from NAPA a couple of years ago (without the purty green strip) had developed surface cracks ... granted, the hose has a pretty extreme bend in it (around 180 degrees) but still not good. I think they changed over their hydraulic goods in-between the time I got the first hose from them and the time I got the newer one. (The newer one is Eaton Weatherhead hose - which I'd assume is decent quality ... but who really knows these days ?)
Some nylon hose sleeve is probably cheap insurance against UV damage.
At any rate, the revised plan at this point - since I'm waiting on the spanner wrench to arrive anyways - is to order all six hoses (2 for the bucket cylinders, and all 4 for the boom cylinders) from DHH ... just a rough guess, but I'd imagine that will save at least $60 ... will order them on Tuesday, and if I'm lucky I should have them by next Friday.
Once the new seals are installed, the cylinders will get degreased, cleaned up, sanded, and fresh coat of paint applied.
Depending on how it goes, I might even order the seal kits for boom cylinders as they're reasonable ($40 each) and rebuild those next.
   / Good morning!!!! #112,403
We have 5 of them including two in the family room, the others are off brands that my late wife like the look of. After 8 1/2 years the Hunters are rock solid and whisper quiet, the off brands have varying degrees of wobble and noise.
When I built my house, I put in HD Hampton bay ceiling fans cause I put one in every room. 5 downstairs and (now with garage addition) 5 upstairs. I’ve had to replace at least 3, one burned, lucky it didn’t start a fire. Only 1 original was hunter. All the replacements are hunters. I have a spare brand new hunter in the garage waiting for another Hampton bay to fail.
   / Good morning!!!! #112,404
Nice project Randy, thanks for sharing.
   / Good morning!!!! #112,405
Good morning, strong west winds have been stripping the new leaves, at this rate all the ash trees will soon be bare. It seems the gusts are coming all the way from America, did you all start your fans up at the same time ? :confused2:
Ron, really nice picture of the cranes.
   / Good morning!!!! #112,406
Good morning, it was a tad chilly in the boat last night (49°F) and going to a high of 81. Wind WNW 4 mph. Sunny.
Because I have no flares, I cannot leave the slip so I will use the boat as a floating cottage.
You guys stay safe
   / Good morning!!!! #112,407
50F clear sky 70 for high.
Outside chores done E muffin time. :licking:
Plans for today...dump run,critter food,fuel,help Mrs. plant vegetables,rest of day just putter.
Enjoy the day all.
   / Good morning!!!! #112,408
Eric.
"strong west winds have been stripping the new leaves, at this rate all the ash trees will soon be bare. It seems the gusts are coming all the way from America, did you all start your fans up at the same time ?"
We just wanted share. ;)
   / Good morning!!!! #112,409
58 high of 78 today maybe thunderstorms later
Will try and cut up tree today that fell on fence and whatever else lady of the house wishes
Nice job Toppop
Prayers for all
Prayers for Drew
   / Good morning!!!! #112,410
64 going to 83, sun returned yesterday pm and I mowed for a couple hours.
Real nice action shot, Randy...project looking good.
(8) 2" x 27' , 5 Ton Ratchet Tie Downs (New/Unused) (A59225)
(8) 2" x 27' , 5...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
YSRT-14 Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
YSRT-14 Skid Steer...
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
SKID STEER BUCKET (A58214)
SKID STEER BUCKET...
