Good morning!!!!
/ Good morning!!!! #213,461
Happy belated Bday BEF!
Balmy 72 this morning but no fog today. Up early this morning to try and get my new burn barrels prepped for fire. I have a huge pile of paper and boxes to catch up on.
Celebrated my 75th birthday yesterday. 🥳 Splurged on a new milling cutter--An 8" facing mill. It should be in next week. I just hope the ole Bridgeport can spin it. :rolleyes: I plan to use it on some small engine heads and perhaps a 3-cyl Kubota head, if necessary.
Everyone have a splendid day. It's the week end so don't take safety for granted.
Happy BD Tinhack. Lot of guys use a single point flycutter to mill wide surfaces on a BP. Just takes a bit longer.
I would assess the warpage, and maybe clean up the opposite side a bit first then cut the head's face. Be careful clamping so you don't warp it more.
One time a friend brought me his brother's outboard motor head. It was warped badly. I had to take off maybe .050" to get it flat. Told him to tell his brother "It was either that or buy a new head" Try it out. 2 stroke.
Happy Anniversary Mr and Mrs M7040!🎊
Yes, Happy Anniversary!
Congratulations. 56 years here and thank God every day for my wonderful wife ❤️
You too Thall!
I'm way behind. Work has been a bear, but a good bear. Still more stuff breaking which is job security. We passed a major external audit which accredits our program. (I knew we would since we set the standards of engineering! ) :)
Had relatives with a 3 year old here last night. That is a workout.
Son is pining over a girl. Told him to get used to it and be patient. God will bring him one someday. His tough classes are catching up to him swamping him with homework. Reading for Honors English proving to be time consuming. I was horrible at homework. (don't tell him that though).
We got about 1.5" last Friday night/Saturday. Better than nothing. Got soaked into the cracks.
Wish I had a huge barn. Friend has 50 x 150, plus a 30' lean to down the back side. I think it is at least 20' tall at the sides, maybe more. It was built to be a hangar originally. It is full.
Could use Popgadget's HVAC furnace knowledge at work. We have a propane heat powered, steam/generator demonstrator that won't light. I believe I've traced it to the igniter. Low ohms at 70 vs 175. Was originally thinking it might be the thermopile (proof of heat sensor). Anyway, I'm going to school on it...
Prayers for our team, our Nation, and for peace around the world.
/ Good morning!!!! #213,462
Well I'm working on my sand/salt pile this week. Having to shift it around a bit, moving all the material to one side so I can redo one of the mafia block walls. Looks like I'm going to end up having to get about 5 more of those blocks and then I'm going to be ordering a ShelterLogic cover for it (ouch). Going to enlarge it a bit, the interior is 12 feet of working room and I'm going to lengthen it to 30 feet from the current 18 so even with a good stock pile I'll be able to at least keep the sander in there or one of the tractors.
Then I mentioned getting fuel oil today, that was even worse then anticipated ended up with 1174 gallons, $3642.19 for that bill. But the house is full and one of my tractor tanks was almost empty, but not now.
Hoping you'll get your propane stove soon.
What size propane tank will you have? We have a 1,000 gallon buried tank purchased by the previous owners. When we first shopped for propane, none of the suppliers could believe we owned the tank until we called one company and they confirmed they were the ones who sold it to the previous owners and we indeed did own it. We get it topped off every 2-3 years in August when prices seem to be at their lowest.
We are fairly diversified with our heating capabilities, wood stove (I'd call that our primary) multiple propane stoves, last year we installed 2 heat pumps (we use them until it gets below 15 degrees, then its the wood stove) and finally base board electric (our last resort but we do have it).
/ Good morning!!!! #213,463
Ponytug, scavengers need to eat too. Just put a hole in your hogs and leave them where they lay.
RE; electric bill, mine so far this year is $1100.oo. Electric lights (all LEDs), water pump, two PCs on all the time, 5 fans on most of the time, a sump pump and the oil furnace. The wood furnace doesn't get lit until the temps get closer to zero. The 60" TV is never on.
Pumped another 100 gallons into the house oil tank after we got back from the vampires. My lottery ticket only cost me $76.oo out of the normal $104.oo. (I get the ticket for 6 months at a time.52 draws. This ticket is good until 26 April 2026.) The difference was 10 free tickets for tonights draw.
LouNY, $3.10/gallon aint all that bad. Try $5.22/U.S. Gallon the last time I filled the big tank. My next fill up will probably be in late February.
I had to call around to get that price, the $3.10 was best of half a dozen many were at $3.40 and $3.60 with one being $3.999. I don't think they liked my response to that figure. Especially when highway #2 is $3.37 with all the highway taxes and sales tax.
And I was telling them I was looking for 800-900 gallons at least.
/ Good morning!!!! #213,464
We got the stove a while back, the propane outfits pissed me off to no end. As it was going to be a new install they wanted to be the ones to supply the tank, propane, materials for piping and the labor, and then tell me how it would be done.
So I had a plumber come in and run the lines the way I wanted, a 1" black iron main line into the house, terminating in a 5 valve manifold with the unused valves having pipe plugs in them for peace of mind, hooked up a 100 pound cylinder to my regulators and then we pressure tested the line, using snoop and a gauge.
Hooked up the stove and lite it off good to go.
Then I purchased a 1000 gallon tank, the outfit that sold it ran the gas pipe (flexible) from the new tank after I dug the trench to the location were the 100 pounder was. Because it was an existing service no issues.
Now after removing my coal insert we are getting a propane one for spot heating.
/ Good morning!!!! #213,465
Good evening all. 47ºF for the start, partly cloudy, windy. Wind 20-35 mph, Sky became clear, and high temp was 61ºF. Made coffee to start day, Men's meeting, office work, mow front yard, lunch nap, finally decided too windy for ride. Didn't get bike or mower maintenance done :( . dinner with group. Last day of wind, will to near normal then another cold front comes through on Friday. Monday will be back to above normal temps.
Resuming Friday 10/24 12:54 AM CDT post 213,184:
Peter(tug) amazing story about the driver reading a book while driving. It does seams that people don't focus on driving like they should.
Drew sorry no deal on RV. You could blame the double bogey on the disappointment from no deal on RV. Nice to hear your landlady is getting a chance to smell the roses.
RS sorry so hard to get info on water well fracking. Really hope you find "the guy" who can improve your well performance.
Thomas Glad you got to leave work early. Has to be frustrating rain comes as you are ready to start leaf control operations.
Bill glad knees are doing better.
Peter(tug) sorry yo have problem filters in your RO system.
Randy(wag) sorry about the cold symptoms hanging in there. Good to hear you were able to make town run and are sleeping good.
RS I see your frustration, you know the tech is out there, but can't find the right person who can really evaluate your well and make 1 or more proposals that will work and cheaper than drilling a new well.
Fuddy nice pics of your Halloween decorations.
Saurday 10/25 3:09 AM CDT:
Drew hope you got the house ready for Landlady and tea. Hope you get more rain. Thanks for the pics of new shed install.
Ron sorry clean up not as far along as you would like. Glad bracket about ready for mounting. Hope found something to putter on. Nice pic.
Happy(NC) glad the day off helped. Hope you made progress on buggy and got oil changed in 4X2. Sorry you don't like cold anymore.
Drew hope hope make the opener more reliable. And find what is tripping the GFI.
Billy sorry about the tick, glad you got it looked at and got the prescription.
Bill sorry knees are complaining so much. Glad you get relief from the insect world during winter. Hope town/dump run went well. Small Business down hear have to make a profit periodically or tax rules change. Hope good energy conservation day.
Thomas guess Boo not a fan of BP blower. Hope lea control went well and you got to watch a good football game.
Ken(tin) glad you are getting rain.
ArlyA sorry the cabin was too warm. Hope clearing the road went well.
WinterDeere thanks for hunting story.
Dennis 74 years of marriage is impressive.
Scott(vt) nice looking family, hoe did you get the grands to sit still long enough for pic?
Mike good to hear from you. Sorry leg misbehaving. Hope you can caught up around the house and on TBN.
More catch up later
prayer for all, especially Jay/Peg, Kyle /Daughter, /mom's breathing, /son's migraines, Mike /BIL in FL, Ron /heart, David(moss) /remodel, /divorce, Buppies /cancer, parathyroid, blood sugar /wife, Thomas /gout, Phil /reflux, Frits /veteran son with mental issues, /granddaughter with Evans Syndrome, Ken /chronic fatigue, Diet not working, Randy(wag) /sister stoke, Scott(vt) /wife's back pain, Steppenwolfe /son-auto immune disorder, Grev /wife's eye, Ted /knee recovery, /retirement & disability red tape, /family issues, /wife back issues and cancer, Lou /eye issues, /heart issues, /wife hip replacement, Doug and wife/health issues, / hand nerve and surgery, /fall and recovery, / wife headaches and heart eval, / David(sadamo)/Sophie's hip or leg pain, Eye recovery, /back issue, Scaredy/shoulder dislocation, /marriage dissolving, / friend stop drinking, Dennis /retirement, /neighbor issues, /brother's lymphoma, /dad surgery recovery, Drew /back operation issues, /friend's wife cancer diagnosis and recovery, Scotty /back pain, Helogabals /wife's friend situation, Fatjay /father broken hip, Ukraine war, Middle East War, and Country.
/ Good morning!!!! #213,466
Took 5 more gallons of used oil to the recycle center. they have 5 gal limit, so at least 2 more 40 mile trips. Hard to believe over 20 miles each way, seems to be just down the road..
But got chinese for lunch.
finally removed the antenna rotor cable, so I could get it out of the way of the last deck board that never got put on against the garage. went out on roof, decided I didn't like trying to work from the edge of the roof, so plan B worked.
Plan B was to loosen the bracket holding the antenna pole, removing the bottom piece, and lowering the antenna down, so I could easily get to the rotor from 3 steps up a ladder. moved he cable out of the way, reinstalled and rotor still not working. So either cable is bad or rotor itself is bad. I should have brought the rotor box out and hooked up a new short cable to test, but didn't. figured as little as I watch tv, ill just turn the pole if i need to adjust the antenna. got it all put back up, and apparently aimed in a proper southernly direction for the tv stations to come in. I only do OTA local, plus streaming now, and I rarely watch anything. My son likes to record and watch wheel of fortune.
still need to rip the last board and install it, but now the cable is finally out of the way. Also need to finish the steps, but want to see if i can find trex fascia first. Maybe I can special order it at HD.
finally put step ladder back in barn, it's been out since spring for the deck work.
Got extension ladder out, and climbed up to clean out the lower back gutter, was clogged at the downspout. Downspout at deck also was clogged, even with a gutter guard now on it. small hole at end of the guard still allowing leaves in. then decided to check the front and side gutters also. All clean now except not going up on the high roof to check the back gutters 3 stories up.
been updating my personnal history file.. maybe someone in my family will care after i'm gone. If not, it helps me to remember fond memories of my past, like when I bought and sold vehicles, when I traveled, etc...
Since retiring, I have been keeping a daily log of what I do, you know in case DOGE asks me what I did last week. I can tell them pretty much what I did the last 40 yrs. When I worked I kept a log the last several years.
Went back to when I built the house, and filled out what i did almost every day, based on my log book i kept. now it's in a spreadsheet, searchable, with a column marking the important stuff..
Oldest son is going to look for a new car, but he did finally figure out how to change the brake light that was out. Had to do some disassembly to get to it.
rain is here now, sounds like hard rain at times, but only .3"on the gauge so far. glad gutters are now clean.
/ Good morning!!!! #213,467
Drinking first cup of coffee. 42° with light rain this morning. Heading to 52° with chance of light rain. Got barn roof sealing done. Then took down carpenter bee traps. Got my combination Blower/Vacuum out. Wanted to switch from vacuum to blower, Could not find the parts. Looked in several places. Going back over the same places later in the day found it. I was looking for piece that was black. Turns out the part was green. Blew leaves out away from garage and house. Grocery shopping today. Then water filter change when I get things put away.
Had a second look at my post on Utilities cost. I put a 1 in place of 2. Should have been $2991.
Looks like road marking paint needs about 3 hours of drying. Road is back open after almost 3 months of being shut down.
Everyone stay well and safe.
Good Morning All.
/ Good morning!!!! #213,468
good morning all
.16 on rain gauge but most of rain not yet here
going to be a wet day and that's fine with me
51 going up to 63 as rain system brings up heat from down South.
no plans for today other than cleaning up office, something way overdue
good job on a rainy day
/ Good morning!!!! #213,469
Good Tractor Morning Ken,
Leaves everywhere , including in the runoff for the driveway, so took out the little wonder and cleared the shared road , driveway and neighbors driveway.
I have the same blower, also have a backpack Echo I think. They are a great combo 🙏
/ Good morning!!!! #213,470
Good Tractor Morning,
Ct, 46 to start going to 58. Intermittent rain until 10am and then pretty steady throughout the day. Looks like an inside day to me.
May have to go back up into the garage attic and do some more junk removal. 😃
I think I mentioned a few days ago I finally found a nice Drake amateur band receiver on EBay. Pleased with it so far, but it needs the plug in CW filters. Managed to find them also on EBay. I should have them by the weekend. 🙏 They should make a big difference once I install them.
Only 5 more days until we go away on vacation to the Dominican Republic. Looking forward to 2 weeks of not doing much. Our youngest son and family are coming down 2 days after we get there, for a week. So I’m sure Nana and I will be busy doing things with the kids 🙏
Thought I would post a picture of the latest rendition of my radio shack/ bedroom 😉
Hope all have a great day 🙏
/ Good morning!!!! #213,471
good morning, 52 going to 62 warmer and raining a little with more to come today
we got the vac shoots and I dont feel anything but wife has a sore arm
Moved some of the firewood and improving the technic to fill the bucket on the loader in one scoop without having to get down and manually do it to get it topped off.
Cody loves the cooler weather since he always has his double coat on
/ Good morning!!!! #213,472
54 and drizzle heading to 64 and sunny this afternoon.
Scotty, that looks like quite the setup. Can you talk to someone in the DR before you go there for vacation?
Yesterday was Yoga day at our house, so I took Della to the mountains to work on my SNP 500 goal. Hiked from Skyland down to some waterfalls on a horse trail and back up a different trail. It was 36F and drizzle/fog/breezy all day...not a day I would have picked, but it was quite nice to be out there.
/ Good morning!!!! #213,473
You can see very little flow since it's been so dry...there is a footbridge visible through the fog.
When we got back to near the parking area, we walked by the stables...I wondered out loud whether any horses were still there, and was answered by a loud neigh. They take the horse down to the valley in the winter
/ Good morning!!!! #213,474
Scott, that's a nice looking setup, as one who used to
own a "radio shack". I'm sure the AC is protected by a surge protector,
but what do you protect the antenna lines with?
lot of very sensitive equipment
are there whole system filters on the input side?
I can only wonder if MOVs affect the bandwidth in some way
and thank you google AI but apparently this can be an issue affecting reception
Yes, metal oxide varistors (MOVs) can
affect radio bandwidth, particularly in high-frequency or radio frequency (RF) circuits, due to their inherent capacitance.
Here is how:
  • Inherent Capacitance: An MOV acts as a dielectric medium between two electrodes, giving it an inherent capacitance (typically in the picofarad range).
  • Frequency-Dependent Reactance: In AC and RF circuits, this capacitance creates a frequency-dependent capacitive reactance (
    Xc=1/(2πfC)cap X c equals 1 / open paren 2 pi f cap C close paren
  • Filtering Effect: Since MOVs are typically connected in parallel to the circuit they are protecting, this capacitance can shunt high-frequency signals to ground, effectively acting as a low-pass filter.
  • Signal Degradation: As the frequency of the signal increases (e.g., in the RF range), the MOV's reactance decreases, allowing more of the signal to be diverted. This can lead to signal attenuation, distortion, and, consequently, a reduction in the available bandwidth of a communications line.
  • Design Consideration: When used on communication lines or in RF applications, the stray capacitance of the MOV is an important parameter to consider during circuit design to ensure it provides surge protection without unintended circuit interference or signal integrity issues.
For standard low-frequency (e.g., 50/60 Hz AC mains) or DC circuits, the effect of the MOV's capacitance is usually minimal and does not significantly impact circuit performance.
/ Good morning!!!! #213,475
nice looking firewood Frits. Plus your equipment always looks good.
after having my hvac system fried by a power surge/lightning/something,
which also belatedly I believe took out my dishwasher, for the first time, I made sure the
dishwasher was a plug in and plugged that into a heavy duty Tripplite surge protector.
our appliances are getting more delicate. They are now online with us.
more circuitry to get zapped and you can bet they don't spend the one dollar or less to build
in a nice MOV into their own product. In a user friendly/accessible spot with a plug in replacement.
no such thing, most of what we buy runs pretty bare.
MOVs are your friend
one Christmas I built Heathkit surge protector strips for my family.
now they are really cheap and should be used everywhere if you don't have a whole house unit.
and even then, on gear like Scott's, I'd have several layers of protection.
I am not sure higher surge ratings are the ultimate test of quality.
other than filtration, what else makes a better surge protector?
.42 rain and a dark rainy morning
/ Good morning!!!! #213,476
Good morning, the low is 35 and going up to 48°F. Wind E 8 mph.
I don't think I've got anything on the go for today. I'll conserve energy. Will check lottery tickets after I post this. I'm not holding my breath.
As far as furnace oil suppliers go, we have a choice, the one I just walked away from or the one I just went to.
The one I walked away from bought the cheapest crappiest oil he could and then doped it up with additives to bring the cetane rating up to almost within spec.
The one I went to is Petro-Canada. Better oil, more bang for my buck and cheaper than the first one. Win, win for me.
The only propane I have on the property is for the BBQ
and that is two 20 lb bottles.
Time for breakfast.
Have a safe day all
/ Good morning!!!! #213,477
Here is how:
If putting MOV's on an antenna, you'd want to find/buy ones specifically designed for the operating frequencies. I design stuff like this for commercial and military applications, but I'm not sure what's out there for consumer applications.
/ Good morning!!!! #213,479
Good morning TBN!!
43 this morning and the rain has stopped for a few days at least and supposed to be breezy this afternoon.
We have gotten 4" of rain in 2 of the last four days. Good soaking rain that we really needed!
Good day yesterday. Finally going to call the electrics done on the buggy!! It starts on first crank. Purrs like a loud kitten, and shuts off with kill switch. Only thing I will do now is wire relay in so it shuts off with key switch ( due today) and whatever lights/acc. I want. I do need to do a little cleanup on the wire looms to make neat and tidy. Then I will turn to welding a couple of pretty rusted cross braces and the Artic Cat.
Not today though. Seems I have been forbidden from the garage today as it is our 38th Anniversary. I think we are going shopping for the garage instead. LOL
We may go look at some seats for the buggy amongst a full day of running here and there together. Just blowin' in the wind. Nice dinner later.
Time for a second cup
Everyone have a great and safe day!!
2013 GREAT DANE 53FT REEFER TRAILER (A59905)
2013 GREAT DANE...
2017 CATERPILLAR 420F2 BACKHOE (A59823)
2017 CATERPILLAR...
2007 Mitsubishi Fuso FE84DW Crew Cab Landscape Dump Truck (A59230)
2007 Mitsubishi...
INSPECTION (A61165)
INSPECTION (A61165)
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
John Deere Z994R (A60462)
John Deere Z994R...
