Good morning!!!!
   / Good morning!!!! #105,811
RNG, is there something special about 350F that is used to rate safes? is it for propane or is that just a random number used, and is 1800 the temp of a big forest/brush fire or house fire? Curious because thinking about a safe, too.
Remember Ray Bradbury's 451 Fahrenheit? 451F is supposed to be the temperature at which paper ignites, but it starts to char at a little over 350F, at least according to the safe man I spoke with. It's also the temperature at which wood starts to char, plastic melts or warps, and "blue" on firearms is destroyed. And 1800F is significant because that turns out to be the temperature when steel starts to soften and warp, which compromises the integrity of the safe body. Once the door seal is broken, hot gasses can enter the interior of the safe and destroy the contents. So what I'm learning is to pick a safe with at least an 1800F temperature rating, and as long a time rating as you can find. Then place the safe on an outside wall, so when the burning house or building collapses, there won't be as much fuel around it, hopefully reducing both the temperature and the time the safe spends soaking in high temperatures.
Security wise, a strong frame around the door, coupled with a very tight fit, pretty much eliminates being able to pry the door open. The safe man gave one of his safes to the local fire department, who then used their hydraulic spreaders and "jaws of life" to try and open it. They failed. They did manage to get in using their giant chainsaw engine driven abrasive cutter, but it took 'em a while.:laughing: And they had to go in through the body, as the bolts are designed to spin if hit by an abrasive wheel or saw, and the door has more than an inch of steel to get through.
The other lesson is that the budget for the safe should reflect the value of what it will store. If all you need is to keep little fingers off your 10/22, you'll be fine with something from the gun store or Costco. The family jewels or grandpa's Purdey are a different story, though.
   / Good morning!!!! #105,812
Kyle I hope your sons rash is in check.
Best wishes to Bird and drives!
   / Good morning!!!! #105,813
Beautiful table tops, Ted.
How do you keep 'em from shooting across the room when you're goin' after 'em with the belt sander?:shocked::laughing:
   / Good morning!!!! #105,814
Wishing Bird and Drivesitfar many many trips around the sun. :)
   / Good morning!!!! #105,815
29°F and light to moderate snow this morning, going up to 35° today. Drove through some light to moderate snow squalls on the way to work this morning. By the time I got to Troy IL, the ground was covered, and traffic was moving about 20mph on US-40. We weren't supposed to get any snow until tomorrow. Oops. The iThingie shows no snow for tomorrow, but the NWS radar says otherwise. There is a sizable blob heading our way. Voice on the radio this morning suggested 1-3", depending on location.
Happy birthday to Bird and DIF.
Table tops are looking good, Ted. Can't go wrong with oak, red or white.
   / Good morning!!!! #105,816
Happy birthday to Bird and Drives! Have a great day!
34F this morning, drizzling a bit..
Got some answers when I talked to benefits dept yesterday, will get more when materials requested arrive in mail next week.
Stay safe, prayers for all.
   / Good morning!!!! #105,817
67°F and no rain
Break out the laser level and shoot some elevations this morning.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #105,818
A raw, overcast 26ºF for today’s low; the present overcast 31ºF presently may be today’s high temperature as this weak, slow moving cold front rolls on through. It looks more likely that a coastal storm will form the weekend but what type of precipitation will fall and where it tracks is still not well defined.
Happy Birthday Bird and Drives!!!!!!!!!! I wish you many more in good health and happiness.
Drew- Your entrance path looks good. Good luck with the rest of the path.
RNG- I hope that your generator ships without incident, you find a permanent solution to your drainage challenge, your auger sites level, and you have a + MRI review with your internist.
Ted- Another awesome woodworking project. Thanks for sharing.
Randy- A BLT pizza reads to be good eats.
Rich and Hawkeye- Good luck with the transitioning.
I hope that everyone is having a decent Tuesday.
My + thoughts, wishes, and prayers.
   / Good morning!!!! #105,819
Happy birthday Bird and drivesitfar
Giyi Telescopic Boom (A57149)
Giyi Telescopic...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
DRAGON 500 BBL ACID TANK (A58216)
DRAGON 500 BBL...
