Good idea or Bad idea, using Marine Grease to lubricate the FEL fittings?
   / Good idea or Bad idea, using Marine Grease to lubricate the FEL fittings? #1
jodebg
Platinum Member
New Hartford, CT
Kubota B-2650
Wondering if it would be of any benefit using marine grease to
Just read some impressive reviews about Johnson/Evinrude Triple Track Grease
which I plan to use to lubricate my FEL control. Now frozen due to condensation.
Need to clean and lubricate.
Got me thinking that it may beneficial to use the same grease to lubricate the FEL?
   / Good idea or Bad idea, using Marine Grease to lubricate the FEL fittings? #2
Don't know why you would need it, but it should not hurt anything. You need to assure compatibility with what is in there, or properly purge the old grease out when you change over. I do not know the Johnson product, but in the Mystik brand, the marine (blue label grease) is a calcium based thickener (like the general purpose green label grease) and is also compatible with lithium complex greases (like the Mystik high temperature red label grease).
Bottom line, I am not sure you gain anything.
   / Good idea or Bad idea, using Marine Grease to lubricate the FEL fittings? #3
a lighter wallet maybe? not much lighter though, right?
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
Skid steer auger plate (A50322)
Skid steer auger...
2020 BOBCAT T770 SKID STEER (A52705)
2020 BOBCAT T770...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
Case Axial-Flow Combine Wheels NO RESERVE (A55301)
Case Axial-Flow...
