Good Full size truck forum
   / Good Full size truck forum #1
PaulT
New York - Upstate
Kubota 2710
I am having some problems with my 97 Chevy 3/4 ton heater. When I have problems with my tractor, or anything remotely connected to tractoring, I just ask this wise group for advice. Does anyone know of a similar web site for full-size (chevy) truck help? Maybe someone here might even know what I should do.
Heater stopped putting out as much heat as it used to late summer. I didn't worry about it then, because it was summer. Now its winter and I miss the heat. It still gets warm, but not hot. I can smell anti-freeze a little when the fans on high, and its really strong outside (if I roll the window down at a drive-thru, for example). The temp gauge runs normal (cycles between 140-195), so I didn't think it was the thermostat. The fluid level doesn't change, so its not leaking anywhere. Just today I find out there's a heater valve available for the truck (parts america online says so). This looks like a valve to close off the heater core from hot water flow. I never knew such a thing existed, or was factory installed on my vehicle. If my k2500 350 cid truly has one of these, it seems like it could be partially stuck. Any ideas??? Do I really have a heater valve, and whats it do, how/when does it activate?
PaulT
   / Good Full size truck forum #2
PaulT, I'll be watching for the responses on this since it really makes me curious. The only times I've seen such a problem that included the odor of antifreeze, the heater core was leaking (but you say the fluid level hasn't changed - that puzzles me). And yes, you definitely have a valve that regulates the flow of the coolant through the heater core. Trouble is, I don't remember enough about that model to help you./w3tcompact/icons/frown.gif
   / Good Full size truck forum #3
I had a similar problem with my Dodge caravan. The temperature guage looked OK....started cold, went to normal range....but I was getting no heat. I had it at the dealer for something else and they got error messages from the computer about the thermostat. New thermostat, good heat. The temperature guage still looks the same. Maybe it's like the thermostat on the wall of my office. It's there for decoration so far as I can tell. Anyhoo, thermostats are cheap.
Chuck
   / Good Full size truck forum #4
Paul
If you smell coolant the heater core is most likely leaking. Check the floor and under the dash on the passenger side. There is a valve to regulate the water flow through the heater core. It would be seen on one of the 5/8" or 3/4" hoses under the hood near the fire wall. If your temp adjustment on the dash is a slide knob, the valve would use a cable to activate it. On GM's this cable disconnects from the valve or from the mechanism on the dash. Once you find the valve you can turn it with pliers tempararily to the hot position until you can repair it.Once this valve is open, the temp. of both inlet and outlet hoses of the heater core should be about the same.If they are not, and your sure the valve is open, the heater core is most likely part way blocked. Sometimes back flushing the system can clean them but not allways.
You should also check your coolant at the radiator when it is stone cold. Checking at the overflow bottle is not acurate if there is a small leak in the system.
Doug T B1700 TLB
   / Good Full size truck forum #6
I had a friend that had the same problem in his car. Turned out after much searching that
the heater core was partially plugged. Went to a radiator shop & they flushed it out & it
is working fine. You may want to try http:// www.wrenchead.com
   / Good Full size truck forum #7
Let's try this instead http://www.wrenchead.com & then go to under the hood. You will have to sign up to go to the
message board.
   / Good Full size truck forum #8
<font color=blue>I am having some problems with my 97 Chevy 3/4 ton heater</font color=blue>
Boy, that is one heavy heater. /w3tcompact/icons/smile.gif
Dave "Gatorboy" Hoffmann
Always good for a chuckle.Thanks for lightening my spirits. /w3tcompact/icons/smile.gif
PaulT
   / Good Full size truck forum #10
Paul,
I don't drive a Chevy, but I've found the best information on my truck from the bulletin board on www.off-road.com (and not just about giant tires and lift kits /w3tcompact/icons/smile.gif). The guys who are on that board tend to be people who've done a lot of work on their vehicles and have seen or heard most any problem you can think of. I don't know anything about the Chevy guys, but I know that there are a lot of them and maybe they can help.
http://www.off-road.com/chevy/
Rob
2014 Ram 4500 Chassis Versalift Bucket Truck (A52377)
2014 Ram 4500...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
2016 John Deere 17 Mini Excavator (A47477)
2016 John Deere 17...
2003 John Deere 310SG (A47477)
2003 John Deere...
2016 CATERPILLAR 325FL EXCAVATOR (A52705)
2016 CATERPILLAR...
