Good drill bits for general purpose - any recommendations
   / Good drill bits for general purpose - any recommendations #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
In https://www.tractorbynet.com/forums/parts-repairs/382798-good-drill-bits.html the focus was for drilling SS.
I'm looking for buying decent single size, like 1/8, 1/4, etc. in quantities of a dozen for less than a $1@. Drilling pilot holes in wood and sheet metal.
There's like 12 PCS, 1/4", HSS Black and Gold Coated Twist Drill Bits, Metal drill, ideal for drilling on mild steel, copper, Aluminum, Zinc alloy etc. Pack in Plastic Bag - - Amazon.com , but I don't trust the reviews, and I found a site SDS Masonry Drills | Drill America that sells their own brand but shipping is about the cost of the bits unless I can find $100 worth to buy. I can't tell the quality of their bits and don't want to buy $100 worth of poor bits.
/edit - And I should have put bulk in the title, I don't want to buy an entire "set" when I really only need 3 sizes.
   / Good drill bits for general purpose - any recommendations #2
   / Good drill bits for general purpose - any recommendations #3
You won't get much of a drill bit for a dollar or less. Just search Ebay or Amazon and choose what fits in your price range, I suspect they will all be about the same quality.
   / Good drill bits for general purpose - any recommendations #4
To go a bit further, try buying one or two cobalt drill bits in the $5 to $10 range. I suspect you will find one of those will outlast 12 of the $1 or less bits.
I buy quite a few bits for the company I work at. The bits we get will range from $10 to $45 each. We learned a long time ago that cheap tooling gets very expensive.
   / Good drill bits for general purpose - any recommendations #5
They are all good IF you know how to sharpen the dull ones.:D
   / Good drill bits for general purpose - any recommendations #6
It's what I should do (and I have a drill DR. I don't use).
Get a fine stone on your bench grinder, a good light, pair of reading glasses and learn how to sharpen them. Takes but a minute.
   / Good drill bits for general purpose - any recommendations #7
I have had good luck with the following brands, they are all USA made:
Chicago Latrobe
Cle-Line
Cleveland
Montana Twist Drill
Norseman
Triumph
Viking
I was also pleasantly surprised by the durability of a MasterForce colbalt bit I bought at Menards for an odd job.
   / Good drill bits for general purpose - any recommendations #8
I have had good luck with Dewalt Cobalt steel bits. I drill i-beams and angle iron all the time for work. Cobalt bits are the only way to go if you will be drilling metals.
   / Good drill bits for general purpose - any recommendations #9
I usually find that buying a set is much cheaper than buying a few loose bits. Home Depot always seems to have decent Dewalt & Milwaukee sets on sale
   / Good drill bits for general purpose - any recommendations #10
M42 cobalt steel bits are the best, but I very much doubt that Home Depot sells that quality.
   / Good drill bits for general purpose - any recommendations #11
   / Good drill bits for general purpose - any recommendations #12
Actually, the very best drills you can buy are Hi-Rock die reclaim drills. They dill anything including glass. I have a set, they ain't cheap either. 5 will set you back a couple hundred bucks. Just the ticket for drilling out heat hardened exhaust manifold studs. Guy bet me one time that I could not drill a hole in a glass pitcher bottom. Got one of my Hi-Rock's a squirt can of plain water (you use water as a lubricant and swarf flusher) and drilled a hole in the bottom, neat as a pin and then the pitcher leaked.....:laughing:
   / Good drill bits for general purpose - any recommendations #13
Buy your jobber drills from an industrial supplier. I stick with brands like Cleveland, union butterfield, triumph, dormer. Cheapo drills are junk and not worth the effort or time. I can still drill holes faster with a dull, quality brand drill bit than with a brand new cheapo that chips or breaks when you look at them.
   / Good drill bits for general purpose - any recommendations #14
   / Good drill bits for general purpose - any recommendations #15
   / Good drill bits for general purpose - any recommendations #16
Been my experience that the cheapo HF (Pittsburg) drills are so cheap, they actually unwind...:D
7-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
7-Gang Reel Mower...
2014 Ford Flex SUV (A59231)
2014 Ford Flex SUV...
2015 CATERPILLAR 815F2 SOIL COMPACTOR (A60429)
2015 CATERPILLAR...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2010 CATERPILLAR 345DL EXCAVATOR (A60429)
2010 CATERPILLAR...
2016 Ford Taurus AWD Sedan (A59231)
2016 Ford Taurus...
