Good Deal ?
/ Good Deal ? #1
Beavis
Kansas
JD 4720
Does this look like a good deal ?
2005 JOHN DEERE 4320 For Sale at TractorHouse.com
2005 John Deere 4320, hydro, with 400X loader, rear SVC, and 330 hours.
What types of things could you do with a 4000 series that you couldn't do with a 3000 series ?
What size of tractor would you need before you could start to pull a 12' disk and actually do some field work?
I appreciate your input, the more I shop, the more options I discover and the tougher the decision becomes.
Have a good weekend.
/ Good Deal ? #2
Beavis, it depends on the type of ground and the type of disk that you have. Me, I pull my 12' offset disk with a D6, and it is all that it will do to pull it in 3rd gear. This other guy that I know has to use a D8 to pull his 12' disk, and he usually uses a D9 because the D8 has to work to hard to pull it.:eek: His disk has 40" blades and weighs around 30,000 lbs.:eek: My disk has 22" blades, weighs about 4,000 lbs. When I pull it, it is digging in 8"-9", that is a lot of drag. There are guys on TBN that pull 10'-12' disks with 50-60hp wheel tractors. I don't know how, except that they must have tandem disks with smaller blades and a lot harder ground than I have.
No I would not buy that John Deere to pull my 12' disk, it would not do it.;)
Good luck with your decision, what ever it is.
2012 Ram 1500 4X4 Pick-Up Truck (A61568)
2012 Ram 1500 4X4...
2012 Ford Transit Connect Passenger Van (A61568)
2012 Ford Transit...
UNUSED RAYTREE RABC44 - 44" ARTICULATING CUTTER (A62131)
UNUSED RAYTREE...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A63118)
1995 Ford F-250...
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
