Good cheaper impact wrench?
   / Good cheaper impact wrench? #12
I have the Milwaukee M18 high torque tool. It is fantastic. Not cheap, but well made and super portable.
Over the years I have purchased HF impacts because they are cheap. Ever so often I buy another thinking the ones I have are or will soon be worn out. I'm up to 4 ½ inchers and they all still work very well. For a commercial operation/operator I might consider high dollar, but for my farm HF suits me.
Milwaukee 2767-22 Impact driver, 2 batts, charger. You will probably never need another heavy duty impact driver again. 1000 on and 1400 reverse.
   / Good cheaper impact wrench? #13
[video]https://www.google.ca/aclk?sa=l&ai=DChcSEwjgkbn8g5_oAhUdhVoFHY4sBuEYABAHGgJ2dQ&sig=AOD64_2v1U8CQ4esXqWAE5IpM2DuwpOvAA&adurl&ctype=5&ved=2ahUKEwiZzrD8g5_oAhVLPd8KHWWGCk8Qvhd6BAgBEFI[/video]
One of these??
Chances are a good impact wrench is more expensive and also requires proper air pressure & volume.
Yikes. Over $100 for a wrench to hammer on. I’ll just keep hammering on regular wrenches. And being 12 point sucks. A socket on a breaker bar would be a lot better.
   / Good cheaper impact wrench? #14
I now use a couple of Dewalt 20volt impact wrenches for everything I do now. I use the Dewalt small impact with a 2 amp/hour small battery for light every day work instead of a ratchet. I then use my big Dewalt impact 1/2 inch with a 5 amp/hour battery for my tough stuff. Battery seems so much easier than using air hose. My 1/2 inch air impact is probably over 40 years old but still works fine, maybe not up to todays standards. I have an old 3/8 inch air impact that was too much trouble to use with an air hose that I never really used it.
The Dewalt impacts were part of the 18 volt trade up program I got from the Dewalt service center. I never really used the 18 volts versions.
   / Good cheaper impact wrench? #15
I have one of the Earthquake 1/2" impacts that have the 3 settings on the back of the housing that was mentioned above a few times, I got it on a sidewalk sale for $50. I'm very impressed with it, on low setting it puts out more torque than my other impacts maxxed out and I think it uses less air doing it.
   / Good cheaper impact wrench? #16
Its not every day I need one, but when I do I have one of those that you whack with a lump hammer. No batteries and I`ve not had a nut its not undone yet, mind it has broken a couple off over the years that were stuck fast.
   / Good cheaper impact wrench? #17
Yikes. Over $100 for a wrench to hammer on. I値l just keep hammering on regular wrenches. And being 12 point sucks. A socket on a breaker bar would be a lot better.
When the going gets tough hammer wrenches rule. Especially with larger bolts/nuts. Pipe will also fit over the end for additional leverage.
For example the higher series of pipe flanges.
   / Good cheaper impact wrench? #18
Another vote for the HF Earthquake, a lot of tool for the money especially for occasional use.
   / Good cheaper impact wrench? #19
I have the red Earthquake mentioned above that HF has sold for many years. That $99 is high. Often there is a coupon for it. Sometimes down to $77 (what I paid) or even rarely $72.
Power is fine for automotive use. Its rare to need a breaker bar on anything.
If I were replacing it today I would spent the extra $20 (?) for the later one rated 50% stronger and slightly lighter.
I also wished I had bought the long-nose variant because any extension twists slightly and absorbs much of the torque. (photo)
Here's HF's whole variety of impact wrenches.
   / Good cheaper impact wrench? #20
I love my impacts with the extended anvils I use them more than the short ones even if I don’t need the extra reach.
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
IH 470 Disk (A50515)
2015 Chevrolet Express 4500 Shuttle Bus (A50323)
2015 Chevrolet...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
