Good cheaper impact wrench?
   / Good cheaper impact wrench? #1
Fallon
Super Member
Parker, CO
Kubota L4060hstc, formerly L3200hst
My current impact wrenches have left me lacking on some recent projects. I have a Ryobi One+ 1/2" drive cordless, but it's not that serious of a gun. Neither is the Kobalt? Air powered one that came in a cheap tool kit. Both usually do ok for lugnuts, but I have to bust out the 18" breaker bar a bit.
At the moment I have a 20-30 year old generator trailer. Weighs 200-300lbs with 20-30 year old rims & tires. Neither impact gun cuts it & the trailer is to light to stay put with the breaker bar. No way to jam the rim against the frame either. I end up with similar problems a few times a year.
It would really only get used in the barn where I have good compressed air. So not terribly concerned about portability.
Any recomendations for a good cheap 1/2" impact gun to be used a couple dozen times a year?
   / Good cheaper impact wrench? #2
The HF "earthquake" gun works pretty well and does not cost too much. 1/2 in. Aluminum Air Impact Wrench It's noticeably more powerful than the old Chicago Pneumatic (cheapo HF) gun I use for most smaller things. Also make sure you have good flowing 3/8 hose to the gun. I swapped my cheap HF quick connects for Milton V high flow ones. I made some other changes at the same time so I don't know if it was them but the difference was huge. They also connect more readily. A Quick Guide to Air Line Couplers and Plugs
   / Good cheaper impact wrench? #3
[video]https://www.google.ca/aclk?sa=l&ai=DChcSEwjgkbn8g5_oAhUdhVoFHY4sBuEYABAHGgJ2dQ&sig=AOD64_2v1U8CQ4esXqWAE5IpM2DuwpOvAA&adurl&ctype=5&ved=2ahUKEwiZzrD8g5_oAhVLPd8KHWWGCk8Qvhd6BAgBEFI[/video]
One of these??
Chances are a good impact wrench is more expensive and also requires proper air pressure & volume.
   / Good cheaper impact wrench? #4
I have the Milwaukee M18 high torque tool. It is fantastic. Not cheap, but well made and super portable.
   / Good cheaper impact wrench? #5
First time I had to change the blades on my 6 foot rotary cutter, I realized that I needed a better impact wrench that what I had. They are torqued to something like 300 pounds, so I had to find something that could deal with that. I bought an Ingersoll Rand Titanium. It wasn't the cheapest, but it had good reviews, and it got the job done. I've had it since 2003 and it works every time I need it.
   / Good cheaper impact wrench? #6
Over the years I have purchased HF impacts because they are cheap. Ever so often I buy another thinking the ones I have are or will soon be worn out. I'm up to 4 ½ inchers and they all still work very well. For a commercial operation/operator I might consider high dollar, but for my farm HF suits me.
   / Good cheaper impact wrench? #7
I also have the Ingersoll Rand titanium. I don't often need it but never fails. I also have a Makita cordless 1/2" impact that does about 95% of what I need.
   / Good cheaper impact wrench? #8
I have a Earthquake 1/2" model,---from HF. Something like 12 or 13 hundred power, so far everything I put it on either comes loose OR breaks off!---it'll snap a 5/8 bolt in a flash. I had to set power down and that's a first as my old Campbell never would take lug nuts off real good. Think the HF was on sale when I got mine, then I got some discounts tossed in so final price was around $109 and some change. They are higher now but this model does work. Also a lot different feel when using it, not hard on hands like others!
Ya, I have plenty of plumbing capacity. 3/4" RapidAir hardline, 1/2" hydraulic hoses connecting the compressor. The retractable reel is only 3/8" hose though. Milton Vs on any places I use QDs.
Not sure how the super cheapo gun I have would compare to some of the HF guns. I'm fine with HF quality for the occasional usage I'd give it. Just not sure how it compares for oomph.
2011 GROVE TMS900E TRUCK CRANE (A50854)
2011 GROVE TMS900E...
UNUSED RAYTREE EXCAVATOR MULCHER (A50460)
UNUSED RAYTREE...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
Ford F-450 Utility Truck (A51039)
Ford F-450 Utility...
