Going orange..maybe..
/ Going orange..maybe.. #21
I agree, in fact the new Massey loader has ~30% more capacity than mine, but they didn't increase the load capacity of the front axle. My comment was more that I just didn't want to spend the money to upgrade, and then find out I didn't get a big of enough upgrade. My wife is open to this whole thing, but I think I only get to do one upgrade!
AGCO/Massey wouldn't rate the loader higher than the front axle could handle... I'm sure they still built in a more than adequate safety margin. The front axle would be the least of my concerns, Iseki builds a tough tractor.
/ Going orange..maybe.. #22
Good Morning Fiziksgeek,
How are the price comparisons between the B2620 and the B2650 ? I would think that may be a determining factor on which machine to buy.
Are you going out to the Kubota dealer on Rt 63 in Bethany, Ct ?
You also mentioned that the wife is on board, but this is the last time, my thought is that you ever decide to buy a larger piece of property that you may be happy you have a slightly larger tractor. The B2650 looks to only be about 2000 to 2200 lbs, not terrible in the weight department !
Good luck with your upgrade !
I probably wouldn't go with the B2620, but wait for B2601. I haven't gotten pricing on a B2601, and its not up on the Kubota website yet, but it should be similar to the Canadian pricing, ~$1250 price difference between B2601 and B2650.
My GC2400 is 1433 lbs, the B2601 is 1632 lbs , and the B2650 is 1786 lbs. If I went with the biggest model, that's ~350 lbs more...but much bigger tires...so maybe the actual PSI on the ground isn't much different. The mower are all about the same weight, and I typically drop the loader for mowing...not always, but usually, as it makes it much more difficult to maneuver around.
I don't think there is a Kubota dealer in Bethany, I think that's a Mahindra dealer. I went to R&S in New Milford, CT, they also have a location in Torrington, CT.
Bigger property probably not in the list in the next 20 years...not that I can really plan that far out, but the wifey doesn't not want to move again!
/ Going orange..maybe.. #24
A BX or similar sized machine would probably be plenty for 1.5 acres, but it never hurts to think about going bigger. Especially if you have plans to expand.
/ Going orange..maybe.. #25
Good Afternoon Fiziksgeek,
Yes the Mahindra dealer has been there for many years, I think its called New England Tractor. There is a new place across from the Bethany FD, not sure of the name of it, but did see some new Kubotas out front.
OK just did a search for Kubota in Bethany, nothing came up, sorry, they were set back from the road a bit, maybe another brand !
I have a Massey Ferguson GC2400....approximately equivalent to a BX2370. The thread is about my search for something bigger....how much bigger is the question!
I think there might be a Kioti dealer over that way....I'm not that familiar with that area though. But they are orange, and from the road, could easily be mistaken for Kubota!
/ Going orange..maybe.. #28
I went from a 1025R to a 3033R so go big and din't look back.
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
24220 (A56859)
24220 (A56859)
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
