Going forward and backward
/ Going forward and backward #1
Jeffory
Rector
JD 5085E
Do I need to push the clutch in when I move the lever to change directions? I have a JD 5085E.
Thanks
/ Going forward and backward #2
Put your foot on the break and stop it then your good to go no clutch necessary.
Thank you
/ Going forward and backward #4
No clutching or braking required on power reverser. The reverser should modulate and make a smooth shift. If it is too jerky, it may need calibration. If transmission does not engage when shuttle shifting, you may have a problem with the seat switch.
Everything works fine. I had two people tell me I was doing it wrong. I was not clutching, always at slow speed, low RPM. Mostly when I move hay.
/ Going forward and backward #6
I have a power reverser tranny also. I move lever to neutral wait a moment then to the other direction.
2005 Dynapac CT262 Sheep's Foot Compactor (A62679)
2005 Dynapac CT262...
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
2009 Stertil Koni ST-1082R 18000lbs 2-Post Auto Lift (A61573)
2009 Stertil Koni...
60 GALLON CATTLE OR FENCE ROW SPRAYER (A63291)
60 GALLON CATTLE...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
WILDKAT 78 ROCK GRAPPLE (A61572)
WILDKAT 78 ROCK...
