Goats for a clean pond?
   / Goats for a clean pond? #11
You don’t have enough mosquito breeding areas around you?
   / Goats for a clean pond? #12
We had two fenced water retention areas at my plant about 2 acres each.
We put 2 goats in each area and it took them only about two months to eat everything they could reach. Then winter came and we had to feed them all winter + you need some supplemental food to keep them healthy. After the third year we had a Bar B Q ....they did a good job.
   / Goats for a clean pond? #13
If it's grass that you want groomed, sheep will work better than goats. Goats will eat grass but it's not in their top 10.
Look at paintings of beautifully landscaped areas from back in the 17th and 18th centuries. Ask yourself how they got their lawnmowers in there from the 20th century. Then remember sheep.
You'll wonder how to contain your sheep. Check out Electric Fence, Ear Tags, Sheep & Goat Equipment, Clippers and Shears, Netting, Backyard Poultry Supplies and more! - Premier1Supplies
   / Goats for a clean pond? #14
Keeping them fenced in and predators will be your big issue. A great pyrenees will solve most predator problem but they like a companion dog, if you dont want two of them. And they bark at everything but they make great herding/watch dogs. You could also go donkey or lama but they are not my cup of tea. Design your area with a two pasture system that you leave open most of the year. One with pond access one without. When August roles around close off the pen without pond access and let it grow up to be a jungle. Then when winter comes move them to that pen this does two things, it keeps them off the water edge during winter and helps offset the hay cost during winter. I used hog panels with hot wire as i am using them to clean hill sides that would be almost impossible to stretch wire across. Start with a small pen for a few months at first to get them to realize your place is home. Like a 20x20 and pellet /hay them. I cannot stress this enough. That way when (not if) they get out they dont run off. (Ask me how i know). And they will come to feed. Also if you have kids, design a two gate system to get into the pen (one gate is always closed) they will slip by you fast). And just electric is not enough you need a solid fence. They will walk right through just electric.
   / Goats for a clean pond? #16
The main thing with pond levy maintenance, (keeping it from growing up) is don't make it too steep. Feather it out into the field so a riding lawn mower can cut the grass if necessary. Most livestock will avoid steep banks.
   / Goats for a clean pond? #17
not sure what you mean, aspen/poplars are top of menu for beavers, after this one did 4 or 5, he started on the maples. i'm on a mt top, 1st one i've encountered, but my place is very wet natured & finally put a bounty on his pelt to my neighbor who took him out.
Pretty sure he was referring to the beaver being allergic to lead... 😄
   / Goats for a clean pond? #18
"And just electric is not enough you need a solid fence. They will walk right through just electric."
To test a fence for goat-proofiness, toss a bucket of water at it. If the water goes through, so will the goats. Goats will catch their horns in 4x6 galvanized panel. You'll need 4x4. If a kid gets out and you toss him back over the fence he'll realize that GOATS CAN FLY! He'll teach the others. Instead, put him in through the gate.
   / Goats for a clean pond? #19
HippieFarmer:
They taste much better if you don't name them.
Might I humbly suggest that naming them appropriately can set the stage of expectation: BBQ, BackStrap, Burger, Osso Buco...Buco, for short.
When my son started his chickens, I told him to teach the kids their table names: dipping flavors for nuggets!
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
JOHN DEERE 1560 - 15' NO TILL GRAIN DRILL (A52708)
JOHN DEERE 1560 -...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
