GO CART PARTS LIST
   / GO CART PARTS LIST #1
LBrown59
Super Star Member
First organized permanent settlement in the northw
2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
GO CART PARTS LIST (Keep in mind this was 50 years or so ago.)
1*washing machine - automatic?
2*Motorized reel type lawn mower. These were used before the rotary mower was invented. Anyone remember them?
3*1934 Plymouth
4*bicycle
5*mine bolts -
6* steel pipe
7*Jack shaft -
8* twin size bed?
(Keep in mind this was 50 years or so ago that my cousin his dad and I built this go cart.)
We used two of the gears that made the agitator go back and forth. This was used to construct the steering mechanics. Un like most automative steering that was made up of a steering gear box tie rods and other linkage we were basically able to use one set up which did the job of a steering gear box and the linkage all in one arrangement. We didn't need tie rods and all that linkage as all that was required was a short connector to each front wheel.
We also used one of the pulleys that rotated the washer drum on one end of the speed reduction jack shaft.
2*lawn mower
Motorized reel mower. These were used before the rotary mower was invented. Anyone remember them?
We used the engine for our power plant.
3*1934 Plymouth
all we used was the steering wheel.
4*bicycle -
All we used was the small rear wheel sprocket to put on the other end of the speed reduction jack shaft. we welded the larger pedal crank sprocket to the inside of the left rear wheel. and used a section of the bicycle chain to connect the two sprockets
5*mine bolts -
The kind they use to support coal mine ceilings to help prevent cave in ins.
We lived about a block from the factory that was one of if not the largest supplier of these bolts to the mining industry. They would buy square stock and turn it down to make the bolts.
We bought 2 pieces of 1" in stock from them and my uncle who was a machinist turned them down on the ends to make the axles.
6*pipe
Probably 3/4" STEEL.
We used pipe for several things. One thing we used it for was the combination motor mount clutch.
7*Jack shaft
Actually the type used to increase or decrease speed depending on which one is your goal.
You might say this became our one speed no reverse transmission.
8*and a twin size bed?
Frame we used it for the chassis, under carriage or what ever you want to call it.
About the only thing we had to buy that wasn't some part off of some old junked thing was the 4 new store bought wheels.
Guess we didn't have any kind of old junk around that had any wheels on it.
Needless to say my cousin & I were the envy of all the other kids in the neighborhood.
50 years ago they all wanted us to take them for a ride on what just might have been the first go cart ever or at least the most unique one ever built.
I wish I would have kept it.
Today it would have been a unique one of a kind keepsake and a really great conversion piece.
The only keep sake I have from it is the last motor that was on it. This motor is way older than I am. Dad used it to saw fire wood for the old coal stove back in the early 1940s.
____________
here is a picture like the mower we used.
http://www.simpletractors.com/club2/topic.asp?TOPIC_ID=49316
   / GO CART PARTS LIST #2
Hey, some people still use reel mowers (or cylinder mowers). Used mostly on high quiality turf, with multiblade cylinders up to about 9 or so can cut very, very fine turf down to a height of 1mm or so. You wouldnt be too popular if you mowed a putting green with a rotary! /forums/images/graemlins/shocked.gif
Also you can have moderate sucess with fewer bladed cylinder, 3 or 4 cutting worse turf, as in roadside embankments, though I would suppose a rotary would be more effective.
They require a fair bit of service, sharpening the blades is not done in your workshop, it requires a special machine to get it done right, the correct operation and set up of one is slightly more complex than other types of mower, you can get it very wrong.
Maybe you guys dont have them as commonly in the US, pretty common round here, many hydraulic triples here too on the golf courses (Ha, now they are fun to drive!)
So enough of the lecture, I guess in answer to your question, yep, I remember them, got 2 working ones out in my shed /forums/images/graemlins/wink.gif
PS, youve already posted this thread before a few months ago, but if you were making go-karts 50 years ago I guess you can be excused a few brain farts /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / GO CART PARTS LIST #3
Not to be outdone by someone not only remembering reel mowers, but having two of them...
I purchased the green one from ebay, and bought the red one while picking it up. Triple reels powered by hydraulic motors, with an onboard pump that is fed by the Steiner's PTO. This just proves there are at least a couple of them in the USA! :>)
David from jax
</font><font color="blue" class="small">(
PS, youve already posted this thread before a few months ago, but if you were making go-karts 50 years ago I guess you can be excused a few brain farts /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif )</font>
I know I know ; but that was clear back in 12/2004
Figure there are a lot of new members/readers that never got to see the original .
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
2016 Toro Workman HD-X 4WD Diesel Utility Cart (A59228)
2016 Toro Workman...
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
2017 JOHN DEERE 310SL BACKHOE (A60429)
2017 JOHN DEERE...
Toyota 8BPU15 3,000 LB Electric Forklift (A59228)
Toyota 8BPU15...
207275 (A52708)
207275 (A52708)
