GM Integrated Brake Controller (ITBC)
/ GM Integrated Brake Controller (ITBC) #11
Yea, it sure sounds like a electronics issue. Like you said it could be something as simple as a bad sensor or perhaps a bad control module itself. I am sure the dealer will figure it out.
Chris
/ GM Integrated Brake Controller (ITBC) #12
Thanks for talking to your friend. That's kind of what I figured, it should be ready to go as far as brakes and lights. Those wires in the pictures near the fender well are only for installing an aftermarket controller, they lead back to the stub wires under the dash. The wire in my truck is actually labeled aftermarket. Yes, you do have to activate the circuit for trailer charging and interior lighting, I guess they don't want 12 volts dangling around if you're not going to use it.
Since the truck is still under warranty I'll have to go back to Chevy to have them check the ITBC. It could just be moisture in the connectors but there is also a pressure transducer on the master cylinder that senses braking demand. The integrated controller also takes imput from the ABS system and I've gotten some error messages on the monthly reports via OnStar about ABS faults, so who knows, a wheel speed sensor could be bad or anything. It also continuously shows error messages on the dashboard display about low tire pressure even though I keep them at 50 psi when unloaded. I guess it wants you to run them at 65-70 psi all the time. Thanks again for all the info.
On my '08 I get a message on dash the from the brake controller showing the trailer when it is connected, I do not recall having to anything other than connecting the trailer. I did have to connect a wire in the under hood fuse box to a pin for charging my dump trailer/rv battery. I found a link to the gm upfitters site when I did this.
I think my tire pressure message comes on below 60 for the front, and maybe 70 for the rear.
/ GM Integrated Brake Controller (ITBC) #13
I just called a friend of a friend for ya. He has a 2010 GMC 2500 Gas with the ITBC and he said he had to do nothing to make his work. He did say he had to buy and install a Maxi-Fuse to make the charge function work for his travel trailer.
Chris
My 08 had the wire rolled up in the fuse box under the hood.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2012 Chrysler Town and Country Van (A59231)
2012 Chrysler Town...
1991 International 4900 Box Truck (A55315)
1991 International...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
