Glyphosphate - application rate advice needed
/ Glyphosphate - application rate advice needed #21
Just a thought. I add plain white vinegar to the round up tank. Its cheap and a dash of DW liquid, roundup mixed, and a healthy splash of vinegar will nuke multiflora rose
/ Glyphosphate - application rate advice needed #22
I use the highly scientific method of the top line of a red solo cup of chemical per one gallon of water. This works for me.
Not sure if this answers your question or not.
/ Glyphosphate - application rate advice needed #23
If you are mixing a tank at 41% concentration you are probably doing it wrong. Post the manufacturers mixing instructions and your tank size.
Too much is a waste of money and bad for the environment. There is a soil residual when you spray. More passes is more bad.
It seems ironic to me to toxify the environment in order to plant "wild flowers". Kinda like using a harpoon gun to "save the whales".
Use a rototiller to cultivate the grass then seed your wildflower mix. No herbicide required.
I agree with what you are saying, but there are programs out there (like the Bee and Butterfly Habitat Fund) that require you to plant a ground cover such as soybean and then spray a few weeks before spreading the wildflower seeds to germinate over the winter. They require you to send photos of each step before they'll supply the seeds.
/ Glyphosphate - application rate advice needed #24
Probably get hammered for this, but ol school pipeline maintenance guy advised a mix of 2 oz glyphosate, + 1 oz 2-4-d per gallon water good squeeze of Dawn to top off the tank. Been using this for years, works great. I’ve had pretty good luck using RM 43 along parts of my fence line where “tye vines” and poison oak are a problem. Careful with that stuff as it a residual & will sterilize the soil.
  • Good Post
Reactions: JWR
/ Glyphosphate - application rate advice needed #25
2-4-D is highly volatile. Never ever use it on even a mild wind. Stuff can go into the air and drift miles away and kill stuff. Was forever getting experience like this to the extension office when I volunteered there.
/ Glyphosphate - application rate advice needed #27
Standard glyphosate concentrate found at TSC and other supply stores is 41%. You want to arrive at roughly 1.5 to 2% in the final mix. Just do the math
/ Glyphosphate - application rate advice needed #28
That could be 16-20oz/gal which is WAY TO MUCH, esp a non-selective herbicide....you would sterilize the ground..
/ Glyphosphate - application rate advice needed #29
I've concluded a 20 yr experiment on 2 tough invasive plants, Mustard and Tumbleweed. I find 2 oz per gallon will eventually kill 90% of it. 2.5 oz per gallon will kill 100%.
The younger the plant the easier they are to kill. GL
/ Glyphosphate - application rate advice needed #30
2 oz of what? The 41% concentrate I assume ?
/ Glyphosphate - application rate advice needed #31
First, in any basic Integrated Pest Mgmt [IPM] course, the first thing they tell you to do is "IDENTIFY THE TARGET SPECIES". Once you do this, there are application rates for each type of plant. It's usually 1 - 2.5/3 oz per gal depending on the plant type. The more broad the leaf and less woody; the less you need/oz/gal.
Next, this is such a small area, you could mark it off and use a backpack or similar sprayer, w a coloring agent. If the majority of the foliage is broadleaf, you could use 1.5oz/gal, hit it all, then 1 week later raise it to 2.5oz and hit anything else remaining. This lessens the post herbicide residual and doesn't contaminate the soil [as bad].
Finally, do not spray anything on a day w winds in excess of 3mph. Make sure the target species is in a growth phase and not dormant. Do not spray w rain in the forecast for 24 hrs, but a rain shower 2-3 days later would be ideal bc it would help translocate the active ingredient from leaves to roots for a complete kill.
Lastly, always follow mix directions and safety measures...wear proper PPE..good luckl
/ Glyphosphate - application rate advice needed #33
Being from CA, you are restricted before you even walk out your door...I do not envy your regulations nor your taxes, but your temps are usually pretty great!
Yes, all target plants should be in a growth phase to move the chemical from leaves to roots [translocation]. If you ever want to accelerate the kill time, spray early in the morning* but spray "under" the leaves. The stomata are located here and they'll get the active ingredient quickly to roots for full kill.
Since youre in CA, your cool temps could go much further into the day then early morning as in S TX...good luck
/ Glyphosphate - application rate advice needed #34
The weather is what we pay for. I worked outdoors for 30 of my 40 years here. Good to know about the leaf underside. Thanks
/ Glyphosphate - application rate advice needed #35
You are correct. I didn’t get my thoughts and typing synced. I do use a solo cup but it’s for a four gallon sprayer. Not a per gallon measurement. Sorry about that and thanks for the correction.
/ Glyphosphate - application rate advice needed #36
No problem.,.hope it all wks out for you!
/ Glyphosphate - application rate advice needed #37
with 41% ,---on the low side early in the season on VERY humid days 2 oz. will do the job. On big tuffer weeds/trees/brush/etc 4 oz. will USUALLY do it but may need a second shot to get strays. IF the 4 oz. dont do it then its time for the bulldozer! lol!
20023 KAWASAKI BAYOU 300 ATV (A64281)
20023 KAWASAKI...
2019 Bobcat T650 (A64126)
2019 Bobcat T650...
UNUSED SDLANCH 14' BI-PARTING IRON GATE (A64281)
UNUSED SDLANCH 14'...
2013 Ford F-150 Ext. Cab Pickup Truck (A61573)
2013 Ford F-150...
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
John Deere 302A 50HP Loader Utility Tractor (A61572)
John Deere 302A...
