glow plugs
   / glow plugs #1
rexnord
Muskego, Wisconsin
Mahindra 2015 4wd
I have a Mahindra 2015 4wd tractor that uses a nkg-724u glow plug 8 volt. Does anyone know of a replacement for this glow plug. The ones from the dealer are around $50.00 each.
   / glow plugs #2
I don't, sorry...but why would such a new glow plug need to be replaced already?
   / glow plugs #3
I had a 2615HST and found the same problem. The plugs for mine were made by NGK and sold only to dealers. My glow plugs were not even listed on the NGK site. I replaced mine 3 times over a 10 year period. I heard they failed due to the glow plug timer cycle being too short. Mahindra had an upgrade kit that included new plugs and timer. I bought the kit and replaced mine. It was plug and play easy to replace. I think the upgraded plugs were rated for higher voltage (10 volts). I sold my 2615 almost 2 years ago but they are still working according to the guy who bought it.
Here's the link for the upgrade. I bought mine from Lawalls (a member here).
http://www.tractorbynet.com/forums/...5095-installing-glow-plug-conversion-kit.html
Other than the upgrade you can check with your local NAPA. They may be able to match the length and threads. If they can go with a 10V plug and it shouldn't burn out so fast.
   / glow plugs
After doing much research I have found a replacement for the NGK 724U. It is a NGK y107Y the only difference is it is a 8.5 volt Tractor starts fine.
Cost $6.93 cents each instead of $45.00 to $50.00 each from the dealer.
2018 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
TOYOTA 42-6FGCU25 LP SIT DOWN FORKLIFT (A52472)
TOYOTA 42-6FGCU25...
2011 INTERNATIONAL MA035 ROUSTABOUT TRUCK (A52472)
2011 INTERNATIONAL...
2014 Dodge Journey SUV (A50324)
2014 Dodge Journey...
WB Mower (A50120)
WB Mower (A50120)
