glow plugs
/ glow plugs #1
badges73
Whangarei NZ
L1501
Hi, can anyone tell me the burn time for the Y-106-1 glow plug ie: how many seconds for a manual hold on glow plug switch??
/ glow plugs #2
When it's below freezing ... 10 to 15 seconds.
Above freezing 10 seconds or less as it gets warmer... the automatic systems will just flash for a fraction of a second when it's hot. KennyV
/ glow plugs
Hi, thanks for your reply.. my system also has a hot coil indicator which in that short of period does not glow ??
/ glow plugs #4
That is a series variable resistance with the glow plugs...
With that series 'heater' with the glow plugs... you can not give it too much time, because as it heats up, it's resistance goes up and that will reduce the current going through the system...
If you watch it closely you will see it glow bright and then dim down just a bit... At that time the glow plugs will be at their hottest... And that is going to be the optimum time for power to the GP's... KennyV
I have one Kubota engine with that system and even in the summer it will take about 10 to 15 seconds to properly heat...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2016 International WorkStar 7400 T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2016 International...
2015 Hagie STS 12 Sprayer (A63111)
2015 Hagie STS 12...
