glow plugs
/ glow plugs #1
badges73
Whangarei NZ
L1501
Hi, can anyone tell me the burn time for the Y-106-1 glow plug ie: how many seconds for a manual hold on glow plug switch??
/ glow plugs #2
When it's below freezing ... 10 to 15 seconds.
Above freezing 10 seconds or less as it gets warmer... the automatic systems will just flash for a fraction of a second when it's hot. KennyV
/ glow plugs
Hi, thanks for your reply.. my system also has a hot coil indicator which in that short of period does not glow ??
/ glow plugs #4
That is a series variable resistance with the glow plugs...
With that series 'heater' with the glow plugs... you can not give it too much time, because as it heats up, it's resistance goes up and that will reduce the current going through the system...
If you watch it closely you will see it glow bright and then dim down just a bit... At that time the glow plugs will be at their hottest... And that is going to be the optimum time for power to the GP's... KennyV
I have one Kubota engine with that system and even in the summer it will take about 10 to 15 seconds to properly heat...
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
2016 Kia Sorento SUV (A61574)
2016 Kia Sorento...
1058 (A63291)
1058 (A63291)
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
