Glow plugs or not?
   / Glow plugs or not? #11
Hey Greg,
The red color just indicates it's off-road diesel. No difference between on-road and off-road diesel with the exception of the taxes you pay for the on-road diesel. Red dye is added to off-road diesel just to indicate that it is intended for farm or off-road use. The dye is used to give away to the DOT anyone who tries to run off-road (non-taxed) diesel in their on-road vehicles. Typically off-road diesel is not #1, or winter blend fuel.
I never noticed a difference in smoke when running #1 and #2 in my diesel truck. If you can get by with running #2 you're better off. #2 burns better and gives slightly better performance. #1 has low-temp additives and doesn't have as many btu's as #2. Usually I'll see a 1-2mpg drop in my truck's mileage when using winterblend or #1 fuel.
If you can get by running #2 without waxing your fuel filter or gelling issues, then I'd stick with #2. If you can only get #2, usually any retailer that carries diesel will sell anti-gel/waxing additive you can mix with your fuel to help in low temps.
John
If I may add just a bit here. #1 diesel is in fact, Kerosene. Here on the west coast we actually begin blending #1 fuel into #2 diesel in early November to winterize it. You can get #1 and #2 diesel dyed in case you want to burn either straight in your fuel tank. You do loose horsepower with straight #1 fuel, but it does, in most cases burn with less smoke. City buses quite often burn taxed #1 year round for less pollution. Also Dyed #2 can, depending on which refinery it comes from, be higher sulfur content which is still legal in off-road application. Some people say they can smell the difference, but I can't.
2018 HINO 268  NON CDL 26FT BOX TRUCK (A54607)
2018 HINO 268 NON...
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
2025 JMR Tree Boom Skid Steer Attachment (A55787)
2025 JMR Tree Boom...
2011 Chevrolet Traverse 1LT SUV (A53424)
2011 Chevrolet...
UNUSED RAYTREE RMA42 HYD AUGER (A54757)
UNUSED RAYTREE...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
