Glow Plugs MANUAL TYPE KIOTI LB 2202
   / Glow Plugs MANUAL TYPE KIOTI LB 2202 #21
Your next step would be to isolate each glow plug by removing the bar or wires that conects them. You can use your test light as a cotinuity tester by hooking the ground clamp to the (+) post of the battery and touch the prob end to the top post of each glow plug; if it lights up it is most likely good. BUT on rare ocations a glow plug will burn out and short to ground. When this happens it usualy burns out the coil indicator. I hope I didn't confuse you.Dan
Do i have to turn the switch back like iam trying to heat them up or just leave off by doing it the way u said.
   / Glow Plugs MANUAL TYPE KIOTI LB 2202 #23
Just leve the key alone. Do the test on each glow plug I would gess you have one or more bad plugs.
I will test tomorrow afternoon and get back with u thank for all your help and everybody else to.
   / Glow Plugs MANUAL TYPE KIOTI LB 2202 #25
part # E5500-65512 for the glow plugs
part# 15401-65561 for the "wire" that connects the glow plugs to each other.
We are gonna get this machine starting for this gentleman---------yep-yep-yep--------
virgil
2004 Freightliner FL70 Garbage Truck, VIN # 1FVABTCS64HM47795 (A57453)
2004 Freightliner...
New/Unused Agrotk YC-26G Sawmill (A57453)
New/Unused Agrotk...
(1) HD 25ft x 24ft Metal Building Frame (A57453)
(1) HD 25ft x 24ft...
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
40 (A52708)
40 (A52708)
1974 Ford F600 Grain Truck (A56436)
1974 Ford F600...
