Glow Plugs MANUAL TYPE KIOTI LB 2202
   / Glow Plugs MANUAL TYPE KIOTI LB 2202 #21
Your next step would be to isolate each glow plug by removing the bar or wires that conects them. You can use your test light as a cotinuity tester by hooking the ground clamp to the (+) post of the battery and touch the prob end to the top post of each glow plug; if it lights up it is most likely good. BUT on rare ocations a glow plug will burn out and short to ground. When this happens it usualy burns out the coil indicator. I hope I didn't confuse you.Dan
Do i have to turn the switch back like iam trying to heat them up or just leave off by doing it the way u said.
   / Glow Plugs MANUAL TYPE KIOTI LB 2202 #23
Just leve the key alone. Do the test on each glow plug I would gess you have one or more bad plugs.
I will test tomorrow afternoon and get back with u thank for all your help and everybody else to.
   / Glow Plugs MANUAL TYPE KIOTI LB 2202 #25
part # E5500-65512 for the glow plugs
part# 15401-65561 for the "wire" that connects the glow plugs to each other.
We are gonna get this machine starting for this gentleman---------yep-yep-yep--------
virgil
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
2009 FORD F-250 XL SUPER DUTY FLATBED TRUCK (A58375)
2009 FORD F-250 XL...
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
12ft 9in Altec Service Bed (A57453)
12ft 9in Altec...
Mini Excavator Quick Coupler (A57149)
Mini Excavator...
SKID STEER ATTACHMENT SHREDDER (A58216)
SKID STEER...
