Glow Plugs MANUAL TYPE KIOTI LB 2202
   / Glow Plugs MANUAL TYPE KIOTI LB 2202 #1
frank360
Lakeland, LA
Mahindra 2615
I'AM HAVING TROUBLE WITH MY GLOW PLUGS DRAINING MY BATTERY WITHIN 35 SECONDS IT DROPS BELOW 12 VOLTS WITH A FULLY CHARGED BATTERY COULD IT BE CAUSED BY MY GLOW PLUG COIL BE'ING BROKEN THANK'S FOR ANY HELP.
   / Glow Plugs MANUAL TYPE KIOTI LB 2202 #2
How old is the battery? You can take the battery of the machine, take it to a parts store, and they can "load it" and see if the battery is weak.
That is where I would start chasing the problem.
virgil
HAD THE BATTERY TESTED IT'S GOOD.
   / Glow Plugs MANUAL TYPE KIOTI LB 2202 #4
will the machine not crank over after heating the plugs?
-----------if so-------------------
You should be able to heat the plugs up pretty good and STILL crank the engine. assuming the battery, cabels, and starter is in good shape.
More dumb questions;
are the battery cables GOOD... as in no corrosion, or "black wire dieses"?
Do you have a GOOD ground?
Is the starter draging, is it wore out?
GOOD, CLEAN connections everywhere?
EVERY THING IS IN GOOD SHAPE NOTHING IS WRONG WITH STARTER OR CABLES
   / Glow Plugs MANUAL TYPE KIOTI LB 2202 #6
OK-- that tell me that the engine will spin like a top when you hit the starter..
is that right?
   / Glow Plugs MANUAL TYPE KIOTI LB 2202 #7
If your glow plug coil is broken you wound not have power to your glow plugs as it is in line.
   / Glow Plugs MANUAL TYPE KIOTI LB 2202 #8
this is true about the glow indicator...
I was wondering if the engine will really spin over..
How long has he had this machine..
If he just bought it, or if he had had it for a while.
If the glow plugs are working, if the starter will shure enough spin the engine, if the air filter is not stopped up, if the fuell filter is not stopped up, if it has enough compression, then it should fire up.
if if if-- I like to start with the simple stuff first before I start pointing my finger at something much more expensive.
I,ve been call out on service calls more than once to discover that the machine was simply out of fuell! It happens.
I'AM NOT SURE IF THE GLOW PLUGS ARE WORKING BUT THE TRACTOR SPINS OVER GOOD. HOW WOULD I CHECK THE GLOW PLUGS
   / Glow Plugs MANUAL TYPE KIOTI LB 2202 #10
Frank, you've posted several questions about this model, but it seems you're not telling us the result of this problem. You say the voltage is dropping below 12 volts with the glow plugs on. But does the tractor start? You say it's draining the battery within 35 seconds, a very long time to have your glow plugs on.
In general, 8-10 seconds of glow plug should be enough unless you're in VERY cold weather. Maybe 8-10 seconds two times, but never 35 seconds in a row.
Please let us know if the tractor is starting, and if so, is the battery coming back up. Ease off on those glow plugs. You seem a little obsessed about the voltage, and a couple of us told you in another post that everything seemed to be okay from the readings you told us. Good luck and let us know what's up.
John
2013 Infiniti JX35 AWD SUV (A50324)
2013 Infiniti JX35...
1263 (A50490)
1263 (A50490)
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2020 INTERNATIONAL...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
