Glow Plug Voltage
/ Glow Plug Voltage
Small gauge wire is at glow plug buss bar . The purpose of the relay is to keep high current loads off switch as do supply full battery voltage to the load circuit . I have throughly reviewed the wiring diagram there is no resistor in the circuit . I’m thinking the reducing wire gauge is limiting current flow measured in voltage at the glow plugs . My othe tractor is a MF , it has full battery voltage at the glow plug buss . I’m thinking of temporally wiring a 12 gauge wire from relay to glow plug and check operation .
The Mahindra will not start cold , new glow plugs already installed .
I’ll keep you posted on results of my test . Thank you for thoughts and responses
/ Glow Plug Voltage #12
My tractor has a MHI motor, believe yours is TYM. But the specs for the glow plug are 10.5v at 9.7amps. There are 3 plugs wired to a common buss. No resistors between the relay and buss. The buss connector has fusible link. Glow plugs should measure 0.55 ohms.
Don’t know if this helps
/ Glow Plug Voltage
That helps a ton ! Thank you . Where were you able to locate this info ? Thank you so much
/ Glow Plug Voltage #14
My machine has a Mitsubishi S3L engine. Found MHI service manual and operation and maintenance manual online. Extremely detailed and very handy.
Nissan Forklift (A55973)
Nissan Forklift...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
2021 Dodge Charger Sedan (A59231)
2021 Dodge Charger...
2023 FORD F-150 (A60736)
2023 FORD F-150...
2015 Ford F-150 Ext. Cab Pickup Truck (A59230)
2015 Ford F-150...
2005 Komatsu HM-400 (A60462)
2005 Komatsu...
