Glow Plug Use
   / Glow Plug Use #1
wsp617
Wisconsin
JD 1070
I have an '89 JD 1070. It was in the low 50's the other morning when I went to start my tractor. I wasn't sure if one needs to use the glow plugs at that temp but I figured it wouldn't hurt. When I went to start it, it just rolled over but didn't fire. Now, this tractor ALWAYS starts so I was confused. I let it sit a few minutes and then she started right up. Was I wrong to use the glow plugs or was there possibly another issue?
   / Glow Plug Use #2
First Welcome.
I don't know what caused the tractor to not start. I would think it would always start with glo plugs no matter the weather.
As for when you NEED glo plugs, I never use them unless it it below zero deg F. My tractor sits in a unheated shed. It will even start then but it starts easier with the count of 5 on the glo plugs.
   / Glow Plug Use #3
It depends on the tractor, we have a Kubota L3830 that only needs the plugs when it is below 30F. We also have a Kubota B7500 that needs the plugs every time you start with a non-warmed up engine, even when it is 90 out.
Aaron Z
2017 Dodge Charger Sedan (A53424)
2017 Dodge Charger...
UNUSED RAYTREE RMDM70 - 70" DISC MULCHER (A54757)
UNUSED RAYTREE...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A53421)
2025 ZWB 59in...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
