Glow Plug timer
   / Glow Plug timer #11
I think I have solved my mystery--using a 12 volt battery and jumper cable on my work bench--I find that it takes at least 7 seconds for a plug to start showing signs of glowing--and gets going good at 8+ seconds. Tried all 3 of my old glow plugs and the same on all. So, next task will be to figure out how to wire up direct to the glow plug wiring with a switch wired directly to the battery. Seems a lot more practical than buying another timer for ~$90 and the possibility of it still not staying on long enough to heat up the plugs. Again, thanks for the help.
Gerald
Interesting to note, thanks for posting your results
   / Glow Plug timer #13
I'd recommend a little push button and a relay
   / Glow Plug timer #14
Bill.. his "timer" takes over the hot length.. & at 3 seconds each time.. its not long enough to get the plugs warm..
Once he turns it off & back on, the plugs have cooled & the 3 second mark starts again..
Gerald.. u can google "push button glow plug" to find the schematic..
Most folks opt to use a Ford {car} starter relay or even a universal starter relay..& a push button or toggle switch.
Use a quality button or toggle as they should be able to hold the load.. same goes w/ the wire..
   / Glow Plug timer #16
You said you ate in S. TX. My question is what temperatures are you taking about? My concern is that with 40-50 degree temps, you have fuel issues as much as glow plug issues.
   / Glow Plug timer #17
I was thinking along the same lines as Coy...... fresh fuel filter is never a bad thing.
I'm having trouble seeing TX with GP problems (Canuck mindset, sorry :)). I do get that some engines are more cold-blooded than others though...
How is your cranking speed ? Esp. if your battery is more than 2-3 years old, I'd start with load testing the battery.
Some GP controllers will keep power applied after the dash light is out, some won't. Something seems a bit strange with those plugs though..... 7+ seconds seems very long to me, but I can't say I've tested 50 different types of plugs.... Was that bench battery fully charged/healthy ?
Rgds, D.
   / Glow Plug timer #18
That'll work, a starter relay would be the ideal item.
I had timer issues on my TC45 and bypassed the system using a starter switch. It's rated for 60A, so I just wired it (along with a fuse) inline from the battery to the bus bar for the plugs. One nice thing is that the glowplug light on the dashboard gets its + from the bus bar, so it illuminates when the button is pressed.
Amazon.com: Grote 82-2151 Starter Switch: Automotive
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
2012 BMW 328i Coupe (A55853)
2012 BMW 328i...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2020 DRAGON ROLL OFF TRAILER (A55745)
2020 DRAGON ROLL...
Year: 1996 Make: Freightliner Model: FLD112SD Vehicle Type: Truck Mileage: Plate: Body Type: (A55852)
Year: 1996 Make...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
