Glow Plug timer
   / Glow Plug timer #11
I think I have solved my mystery--using a 12 volt battery and jumper cable on my work bench--I find that it takes at least 7 seconds for a plug to start showing signs of glowing--and gets going good at 8+ seconds. Tried all 3 of my old glow plugs and the same on all. So, next task will be to figure out how to wire up direct to the glow plug wiring with a switch wired directly to the battery. Seems a lot more practical than buying another timer for ~$90 and the possibility of it still not staying on long enough to heat up the plugs. Again, thanks for the help.
Gerald
Interesting to note, thanks for posting your results
   / Glow Plug timer #13
I'd recommend a little push button and a relay
   / Glow Plug timer #14
Bill.. his "timer" takes over the hot length.. & at 3 seconds each time.. its not long enough to get the plugs warm..
Once he turns it off & back on, the plugs have cooled & the 3 second mark starts again..
Gerald.. u can google "push button glow plug" to find the schematic..
Most folks opt to use a Ford {car} starter relay or even a universal starter relay..& a push button or toggle switch.
Use a quality button or toggle as they should be able to hold the load.. same goes w/ the wire..
   / Glow Plug timer #16
You said you ate in S. TX. My question is what temperatures are you taking about? My concern is that with 40-50 degree temps, you have fuel issues as much as glow plug issues.
   / Glow Plug timer #17
I was thinking along the same lines as Coy...... fresh fuel filter is never a bad thing.
I'm having trouble seeing TX with GP problems (Canuck mindset, sorry :)). I do get that some engines are more cold-blooded than others though...
How is your cranking speed ? Esp. if your battery is more than 2-3 years old, I'd start with load testing the battery.
Some GP controllers will keep power applied after the dash light is out, some won't. Something seems a bit strange with those plugs though..... 7+ seconds seems very long to me, but I can't say I've tested 50 different types of plugs.... Was that bench battery fully charged/healthy ?
Rgds, D.
   / Glow Plug timer #18
That'll work, a starter relay would be the ideal item.
I had timer issues on my TC45 and bypassed the system using a starter switch. It's rated for 60A, so I just wired it (along with a fuse) inline from the battery to the bus bar for the plugs. One nice thing is that the glowplug light on the dashboard gets its + from the bus bar, so it illuminates when the button is pressed.
Amazon.com: Grote 82-2151 Starter Switch: Automotive
HIGH-END MINI GOLF CART (A55745)
HIGH-END MINI GOLF...
GROUND PROTECTION PAD 8X4 15 COUNT (A55745)
GROUND PROTECTION...
golf cart (A55787)
golf cart (A55787)
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A54814)
2016 Autocar...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
