Glow Plug Timer Testing???
/ Glow Plug Timer Testing??? #1
dawii
sandra55
My glow plug indicator light (and glow plug function) no longer come on when I turn on the ignition. I checked the glow plug relay and that appears to operate fine, and the glow plugs test out fine. I suspect that the glow plug timer (LG4056/LS TRG750 - 4 pin glow timer) may be the problem, but I don't want to spend the money buying parts unless I'm sure it's the timer that's failed - how do you test the timer? No indicator as to which lead is which (three connectors on one row and one on the second row) - Tractor is a DTC300; but I think the circuits are the same on most tractors of that size.
I traced out the wires from the timer to the relay (a green & a red wire) that are on pin 1 & 3, so I assumed that if I apply 12v to pins 2 & 4, they should energize the other two for 20-30 seconds (thus opening the circuit for the glow plugs). When I tried it, I got 12v to pin 3, but no connection to pin 1 (either voltage or open circuit to any of the pins); and the power never shut off; I would assume that tells me I have a bad timer; but I'm no electronics guy - anyone confirm that this sounds right?
For any future timer testers :), I ordered a new timer and installed it - and voila, works again.
17394SFL (A61568)
17394SFL (A61568)
2017 Lincoln MKC Multipurpose Vehicle (MPV), VIN # 5LMCJ2C95HUL50284 (A65563)
2017 Lincoln MKC...
Dodge 5500 Bucket Truck (A63689)
Dodge 5500 Bucket...
2013 KENWORTH T370 DUMP TRUCK (A65054)
2013 KENWORTH T370...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2021 Ford F-150...
