Glow plug thermostat?
/ Glow plug thermostat? #1
CO_Farmer
Loveland, Colorado
Yanmar YM2500
It hasn't been below 40 degrees since I bought my B7800 last spring.
I have never seen the glow plug indicator light all summer. Is there a thermostat in the glow plug heaters
with a minimum temp before they turn on, or should I be looking at other electrical things, including a bad light bulb?
/ Glow plug thermostat? #2
Mine lights the dash indicator and I can hear the relay, every time I start it. The warmer the engine is, the shorter the on cycle is. Even at 95 deg, it will come on for a brief time. Do you hear the relay click at all?
/ Glow plug thermostat? #3
I'm not sure about the 7800 but like dstig1 my light comes on every time I go to start it.
Dave, thanks. No, I don't hear the relay click, so I guess I'll check fuses (if I can find them- LOL) and find a shop manual or search more online.
/ Glow plug thermostat? #5
I am sure the 7800 is the same as all the B's. The glow plugs are activated when you turn the key past 'on' but not to 'start'. The dash light will stay on as long as you hold the key in that position.
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
2020 HYDREMA 922GHM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2019 Ford F-550 Truck, VIN # 1FDUF5GT5KDA27067 (A65563)
2019 Ford F-550...
ASSET DESCRIPTIONS & CONDITION (A59914)
ASSET DESCRIPTIONS...
