Glow plug operation
/ Glow plug operation #1
rnbrn21
Bronze Member
Honeoye Falls, NY
Kubota BX24
I own a BX24 and I think there is something wrong with the glow plug operation. I want to start by saying that the tractor starts and runs fine, but I don't think the glow plugs are operating correctly. I started it yesterday at about 25 Deg.F and when I turn the key switch to the first setting I get the clicking but the glow light indicator does not come on. When I turn over the engine the glow plug indicator light comes on while I'm cranking and until I release the key switch after it starts. It takes about 15 seconds for it to start and there is black smoke for a short time after it starts. I've owned this tractor for about 2 years now and I distinctly remember the glow plug indicator light coming on as long as I had the switch in the prestart position. Any input would be appreciated.
Ron Brown
Rochester, NY
/ Glow plug operation #2
Ron, if you hold the keyswitch about half-way between ON and START, the glow plugs operate... you'll notice the indicator on.
In very cold weather, I usually hold my BX24 there for about 10 seconds or so, then turn further to engage the starter. It always starts right away, with just a little puff of black smoke.
There really is no 'prestart' detent, at least not on my BX24.
Pete
/ Glow plug operation #3
There really is no 'prestart' detent, at least not on my BX24.Pete
Exactly. My BX23 has no detent either, just turn the key until you feel the start position coming on and hold..My glow plugs come on every time even after 10 years. You'll get a small belch of black smoke but shouldn't be excessive.
I have to Thank You for your responces. I reread both responses and realized what you were saying. I could have sworn that the glow plug indicator came on with the key switch in the on position. I just went out and tried moving the switch between on and start and behold the glow plug indicator came on. I'm glad to be wrong because it means there is nothing wrong with my tractor. I also learned by watching a YouTube video that if after starting your tractor if it is running really rough you can move the key switch back to the glow plug on point to give the engine a little more warmth to smooth it out. I haven't tried it though.
/ Glow plug operation #5
My B26 owner's manual has the following guidelines for holding the switch in the glow plug position (between ON and START, glow plug light lit up) prior to start:
2-3 seconds when over 32F
5 seconds for 23F to 32F
10 seconds for 5F to 23F
Since it doesn't have additional guidance past 10 seconds, I'm guessing past 10 seconds either doesn't get the glow plugs any hotter OR gets them too hot and is therefore bad for them.
/ Glow plug operation #6
There is no reason to ever do this.
wrooster
/ Glow plug operation #8
Cycling twice B4 starting is not a problem but while running could cost you a glow plug or two.
Glowing while running will add additional heat to the plug filament all while vibrating.
Think light bulbs; much more fragile when hot.
/ Glow plug operation #9
Not sure of the durability of the glow plugs Kubota uses but the very good glow plugs used in diesel autos and at least some tractors are pre, start, and post heating. The computer on those engines controls heating until the engine is running smoothly. Remember the glow plug in a combustion chamber is not an air heater. It instead provides a hot point that will start the combustion burn before compression only gets it to that temperature. If it was heating air, that air is gone the first exhaust stroke. So when you crank over the engine the glow plugs trigger combustion, but without power they quickly cool but by that time, the designers hope the engine is running. BERU glow plugs heat up to 180 seconds post heat.
/ Glow plug operation #10
My 1986 or so B4200 calls for 15 seconds on the Glow plug above freezing and 30 seconds below freezing. It may take two to three 30 second shots before it will run in winter. So for 25+ year old Glow plugs, they are pretty robust.
/ Glow plug operation #11
Does a B2320 work the same way?
I could swear mine come on, in the On position.
But now I'm not so sure.
/ Glow plug operation #12
Although the glow plug lamp does not show it, there is a post start glow plug timer on my Kioti. At least the service manual says so.
To start the tractor, if the block temperature is below 86F the glow plug lamp will come on for approximately 8 seconds. Then turn the key further to the start position. The engine will start . The post start glow plug timer will run for approximately 15 seconds while the engine is running.
By the way the Kioti is the easiest starting and smoothest startup of any tractor I have ever owned, including my New Holland and two Kubota's. Just a bump of the key in the start position will fire it off. The hardest starting tractor I have ever owned was the Long 2360. Lots of manual glowing and cranking and slobbering to get that bad boy off and running.
/ Glow plug operation #13
-------------- I also learned by watching a YouTube video that if after starting your tractor if it is running really rough you can move the key switch back to the glow plug on point to give the engine a little more warmth to smooth it out. I haven't tried it though.
wrooster
My TORO + Loader has a separate glow plug switch. When I start it in cold weather, I hold the switch on after it starts, until it runs smooth. Been doing it for ten years, you can see the current draw on the ammeter, so I know they are working.
My 2006 GMC Duramax has an indicator that goes out when it is OK to start, but by looking at the voltmeter, the glow plugs are still on. After it starts they stay on quite awhile, then they cycle off on back on while driving for several miles, if it is real cold.
/ Glow plug operation #14
My '89 Suburban did the same thing..I'd see the GP light cycle every so often until there was operating temp showing.
/ Glow plug operation #15
I'm an idiot. I've been starting my tractor wrong since I got it. Not sure if I was starting my BX25 wrong as well.
I don't use it much in the winter so it was not really too big a deal.
But I did start it the other day when it was like 20F out and was in the teens overnight.
I decided to *think* and actually use the glow plugs this time. It started up instantly. Much quicker than even a hot summer day.
I'll bet you others are messing this up too.
There are 4 Positions on the Key, not 3.
Off, Run, Glow and Start.
Some cars will combine Run and Glow and automatically run the glow plugs in the Run position and that's what I was doing, which did nothing.
I think the glow plugs might continue running in the start position (while cranking).
/ Glow plug operation #16
There is no possible way to engage the glow plugs on mine while the engine is running( not that I want to)... To engage you have to turn the switch to the left before starting. On my dad's Grand it's auto and engages before starting. I though about adding the auto engage timer to mine but read how many timers had gone bad on older tractors and decided against it. I hardly ever need to use the plugs anyways.
2018 VOLVO DD25B DOUBLE DRUM ROLLER (A62129)
2018 VOLVO DD25B...
DEUTZ MARATHON...
2015 Dodge Grand Caravan Van (A61569)
2015 Dodge Grand...
2003 V.E. ENTERPRISES 500 BBL FRAC TANK (A60736)
2003 V.E...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2023 GMC 1500 Sierra Elevation Crew Cab 4x4 Pickup Truck (A60352)
2023 GMC 1500...
