glow plug operation ym165
/ glow plug operation ym165 #1
darwyns
Hockley,Texas
hello all just seeking explanation of how the thermal glow plug system operates also what do i need to do to operate it correctly thanks
/ glow plug operation ym165 #2
hey,
if it's at all like a 169, it pre-heats the air / combustion chamber that there's warmth when the fuel tries to be ignited. I would pre-heat the cylinders with compression release, cranking for about 10 secs. Then I would turn the counter-clockwise for about another 10 secs, then turn to right to start. I would only use thermostart under 40F in my case. Should fire right up otherwise.
e.g. this am it was 48F, pre-heated cylinders, and fired right up.. Anyway, i hope this helps a bit.
2018 FORD F-150 (A67714)
2018 FORD F-150...
PORTA POTTY (A68842)
2012 EXAOS 130BBL VACCUM TRAILER (A67714)
2012 EXAOS 130BBL...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
PALLET OF 51 X 41 X16 BRASS WEAR RINGS (A68842)
PALLET OF 51 X 41...
2016 CAT 299D2 SKIDSTEER W/MULCHER HEAD (A67714)
2016 CAT 299D2...
