Glow plug issue
/ Glow plug issue #1
jhaulenbeek
Mahindra 2638
Mahindra 2638, with brand new battery, turns over but won’t start because glow plugs don’t get hot. Glow plug dash indicator doesn’t light up.
/ Glow plug issue #2
Got multimeter?.....Check to see if you are getting power to glow plugs, if not trace circuit back through any relays/switches/fuses till you find power, most likely problem is in general area where you first find power ... Wiring diagram for tractor will help....
/ Glow plug issue #3
Do you have a fuse on your glow plug circuit? If that's good follow Wrangler's advice.
/ Glow plug issue #4
There is a fuseable link that is attached to the glow plug bar, mine was on the first plug. Mine had intermittent power to the bar. There is a tab to unlock it and it wouldn't come off. After removing it from the post on the first plug, i would gat a hot reading with a test light and if it moved the light would go out. Its hard to see in the pic, but there was a little bit of melting on the plug/link. I replaced the fuseable link and she fired right up. It was $5 at the auto parts store
Mine is a 1526 but same issue. it was getting harder to start blowing white smoke and then it wouldn't start at all
/ Glow plug issue #5
