Glow plug issue
/ Glow plug issue #1
jhaulenbeek
Mahindra 2638
Mahindra 2638, with brand new battery, turns over but won’t start because glow plugs don’t get hot. Glow plug dash indicator doesn’t light up.
/ Glow plug issue #2
Got multimeter?.....Check to see if you are getting power to glow plugs, if not trace circuit back through any relays/switches/fuses till you find power, most likely problem is in general area where you first find power ... Wiring diagram for tractor will help....
/ Glow plug issue #3
Do you have a fuse on your glow plug circuit? If that's good follow Wrangler's advice.
/ Glow plug issue #4
There is a fuseable link that is attached to the glow plug bar, mine was on the first plug. Mine had intermittent power to the bar. There is a tab to unlock it and it wouldn't come off. After removing it from the post on the first plug, i would gat a hot reading with a test light and if it moved the light would go out. Its hard to see in the pic, but there was a little bit of melting on the plug/link. I replaced the fuseable link and she fired right up. It was $5 at the auto parts store
Mine is a 1526 but same issue. it was getting harder to start blowing white smoke and then it wouldn't start at all
/ Glow plug issue #5
Deere 50D (A60462)
Deere 50D (A60462)
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
CAT 272D3 SKID STEER (A65053)
CAT 272D3 SKID...
