glow coil question -
   / glow coil question - #1
fsteyer
Vermont
Mitsubishi D2000
Hi -
the glow coil on my dash doesn't glow any longer. I checked the glow plug and is has continuity. Akso the coil is not physically broken and continuous. Any suggestions how to troublehoot are appreciated.
Hi -
   / glow coil question - #3
Just a dumb question, but are you sure it is turning on? Now that the temps are up, the automaticly controlled ones may not turn on.
If it is turning on, is the dash bulb out?
jb
   / glow coil question - #4
jb
Thanks .
the dash bulb (coil) isn't glowing ... if that's what you're asking.
Thanks
Thanks .
Thanks
   / glow coil question - #7
Tractor glow plugs get hot when battery voltage is directed to them, either a simple circuit though a fuse and Ignition switch position, or though the use of a timer control unit and coolant sensor. My tractor has only a ignition switch position just before the start position that turns the plugs on, and it's up to me to time it. So the power would come from the battery, through a fuse, through the ign sw to the glow plugs. The voltage is grounded throught the plug's resistor core into the block. Troubleshooting would involve a test light or volt meter probing at the bulb feed and at the glow plugs.You can also eyeball the bulb if it's easy to remove. You can compare resistance values for each glow plug with the wires off. Then check for battery voltage with glow plugs energized. A quick check of the fuse might be good starting point though. A more complex system with a timer or computor control might need a peek at the wire diagram. For instance, some modern diesel cars cycle the glow plugs when the driver's door is opened, so that there is no "wait to start" . Of course the system is computor controlled, and depends on many sensors to decide if glow plugs are needed and for how long.
   / glow coil question - #8
thank you for the indepth answer. Mine is a simple circuit ... battery --- ign sw --- push button --- glow coil --- glow plug. It all is operational, I am just wondering why the coil doesn't visibly glow.
Thanks ...
Thanks ...
Club Car Electric Golf Cart (A50121)
Club Car Electric...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2005 Chevrolet C4500 Altec Bucket Truck (A50323)
2005 Chevrolet...
2014 Case IH MD92 Disk Mower (A50515)
2014 Case IH MD92...
2001  WABASH 53FT DRY VAN TRAILER (A52141)
2001 WABASH 53FT...
