Global Warming?
Status
Not open for further replies.
/ Global Warming? #621
If you have ever seen a glacier the streaks in the ice are sections of the flow traveling at different speeds. The center of the flow travels fastest. The uneven travel speed creates crevasses. Opening and closing at different travel speeds./QUOTE]
Sure have seen a glacier or two. Even travelled across/up/over them on ski's. Even tied up to other fellows with rope's when doing this. Fortunetly the oportunity to see the ice varving in a crevice never occured. If'n I was at home with access to my pictures there would be lot's of pictures available.
Flow impedments and Boundary layer friction make for a myriad of unique crevase forming situations.:)
/ Global Warming? #624
Actually, sir, you are not correct when you say, "that ice is composed of salt water." Au contaire, mon ami... If you melt some of that ice the water is almost pure! It is NOT composed OF salt water. It was made FROM salt water and that is NOT the same thing.
This will explain why there are people that talk about moving Ice Bergs to Cities requiring fresh water!:)
/ Global Warming? #625
I believe it's also related to bull-pucky.
Well, if it is soft bull-pucky, you are very close to defining the more technical meaning of the word. When I looked it up, it comes from the Nordic parts of Europe, and translates to roughly "soft excrement."
/ Global Warming? #626
Actually, sir, you are not correct when you say, "that ice is composed of salt water." Au contraire, mon ami... If you melt some of that ice the water is almost pure! It is NOT composed OF salt water. It was made FROM salt water and that is NOT the same thing.
As the ocean water begins to freeze, small needle-like ice crystals called frazil form. These crystals are typically 3 to 4 millimeters in diameter. Because salt doesn't freeze, the crystals expel salt into the water, and frazil crystals consist of nearly pure fresh water.
I was on Viet Nam GI bill when I took 14 upper division semester hours of physical oceanography in the physics department at San Diego State University so consider the above mini-tutorial as yet another federal tax rebate. ;)
It has been years since I had an opportunity to dredge up those old memories. Thanks... ;)
Oh, if anyone want some interesting reading (real science not hyperbole) then Icelights: Your Burning Questions About Ice & Climate
Pat
Frazil crystals are correct but don't forget Spicules starting the process.
Your partially right about the salt water freezing. In the process of cooling the salinity of the top layers increases the convective currents. The more rapid the freezing the more sea water is trapped between the ice crystals. The actual brine content depends on the age of the ice, temperature changes and how fast it freezes. Sea ice that has made ridges by compression will drain most of the salt crystals out and can be used for fresh water. Sea ice that has remained flat will be soggy and deteriorate and retain the brine.
U.S.M.C. Meteorology 1968-1975. With special assignments and TAD. Been there done it.
/ Global Warming? #627
Ice bergs start out as fresh water. They are a result of land based ice streams "Glaciers" breaking off into the ocean. Sea ice is a different animal.
/ Global Warming? #628
Manmade? Well, that is always going to be in doubt in the minds of a few until we quit dumping CO2 into the atmosphere and then see a temperature decline. That won't happen. But climate change. How about the Gulf Stream quits flowing?
The CO2 has been higher in past cycles of climate changes. Ocean currents are dependent on the Rotation of the Earth, the Salinity of the water and Cyclic periods of heating and cooling of the ocean surface.
Last I heard the Gulf Stream was still moving quite well.
Everytime a Volcano erupts the temperature decreases because of the particles in the atmosphere. Several periods of "no summer" have occurred in the last 200 years. Krakatoa and Mt Pinatubo come to mind.
/ Global Warming? #629
I think this is correct. I have heard it that way. I think you made many points that are correct in regard to this discussion.
/ Global Warming? #630
Thanks.
In regards to patrick_g. The information in this site is very informative. Icelights: Your Burning Questions About Ice & Climate If you read the various sidebars and posts you will see we are a long way from total disaster. If people and governments get past the panic and realize a warm cycle is happening adaptations can be made. In ten thousand years we can adapt for a cold cycle. The Earth will never be stable. It never was in the past, why should it be in the future.
For you volcanoligists. Why would you ever bomb a volcano? | Eruptions | Big Think
This gives a much better idea on how man has tried to alter nature and the futility in the long run. I remember the Etna bombings. If I remember correctly the original plan was to bomb the volcano into submission. The plan was changed to divert the lava flow.
/ Global Warming? #631
/ Global Warming? #632
Originally Posted by rsewill View Post
The interesting thing is that many of us will live long enough to absolutely have proof positive of manmade global climate change
Actually I HAVE lived long enough to prove scientist that predict Global Cooling are erroneous.
In the 70's ( yes I was alive way back then ) the smartest Scientists on the planet predicted GLOW BULL - Cooling )
Oh ya it was big news HUGE news in fact. They scared the entire planet.
For your edification here is the abstract.....
Effects on the global temperature of large increases in carbon dioxide and aerosol densities in the atmosphere of Earth have been computed. It is found that, although the addition of carbon dioxide in the atmosphere does increase the surface temperature, the rate of temperature increase diminishes with increasing carbon dioxide in the atmosphere. For aerosols, however, the net effect of increase in density is to reduce the surface temperature of Earth. Because of the exponential dependence of the backscattering, the rate of temperature decrease is augmented with increasing aerosol content. An increase by only a factor of 4 in global aerosol background concentration may be sufficient to reduce the surface temperature by as much as 3.5 ï½° K. If sustained over a period of several years, such a temperature decrease over the whole globe is believed to be sufficient to trigger an ice age.
No one has ever answered how the same "brilliant" scientists can look at the EXACT SAME INFORMATION and come up with TWO POLAR OPPOSITE conclusions.
So here is my conclusion because I think for myself and don't let Al Gore think for me.
If one Scientist says GLOW-BULL cooling is eminent, and another Scientist says GLOW- BULL warming is eminent...........in every book in the Universe that mens it's a DRAW., A TIE, EQUAL, ADVANTAGE NONE, ZERO-ZERO, NADA, ZILCH, ei mitè’¿n, ingenting, Ничего, Nada, Niente, Τίποτα ,Niets, khe chaina, Gar nichts, Wala lang, kuch nahin, 무가치 , nashi nai, ekkert, Nihil,
/ Global Warming? #633
Effects on the global temperature of large increases in carbon dioxide and aerosol densities in the atmosphere of Earth have been computed. It is found that, although the addition of carbon dioxide in the atmosphere does increase the surface temperature, the rate of temperature increase diminishes with increasing carbon dioxide in the atmosphere. For aerosols, however, the net effect of increase in density is to reduce the surface temperature of Earth. Because of the exponential dependence of the backscattering, the rate of temperature decrease is augmented with increasing aerosol content. An increase by only a factor of 4 in global aerosol background concentration may be sufficient to reduce the surface temperature by as much as 3.5 ー K. If sustained over a period of several years, such a temperature decrease over the whole globe is believed to be sufficient to trigger an ice age.
If one Scientist says GLOW-BULL cooling is eminent, and another Scientist says GLOW- BULL warming is eminent...........in every book in the Universe that mens it's a DRAW., A TIE, EQUAL, ADVANTAGE NONE, ZERO-ZERO, NADA, ZILCH, ei mit蒿n, ingenting, Ничего, Nada, Niente, Τίποτα ,Niets, khe chaina, Gar nichts, Wala lang, kuch nahin, 무가치 , nashi nai, ekkert, Nihil,
When I was a Meteorologist in the Marine Corps (1968-1975) the consensus was global cooling.
I congratulate on you on your linguist ability. Khang-ah
/ Global Warming? #634
Hi
Effects on the global temperature of large increases in carbon dioxide and aerosol densities in the atmosphere of Earth have been computed. It is found that, although the addition of carbon dioxide in the atmosphere does increase the surface temperature, the rate of temperature increase diminishes with increasing carbon dioxide in the atmosphere. For aerosols, however, the net effect of increase in density is to reduce the surface temperature of Earth. Because of the exponential dependence of the backscattering, the rate of temperature decrease is augmented with increasing aerosol content. An increase by only a factor of 4 in global aerosol background concentration may be sufficient to reduce the surface temperature by as much as 3.5 ?ー K. If sustained over a period of several years, such a temperature decrease over the whole globe is believed to be sufficient to trigger an ice age.
Nihil,
Here is a quote from Wikipedia Global cooling - Wikipedia, the free encyclopedia
"An early numerical computation of climate effects was published in the journal Science in July 1971 as a paper by S. Ichtiaque Rasool and Stephen H. Schneider, titled "Atmospheric Carbon Dioxide and Aerosols: Effects of Large Increases on Global Climate". The paper used rudimentary data and equations to compute the possible future effects of large increases in the densities in the atmosphere of two types of human environmental emissions .... " snipped
"Both their equations and their data were badly flawed, as was soon pointed out by other scientists and confirmed by Schneider himself.[21] In January 1972, Charlson et al. pointed out that with other reasonable assumptions, the model produced the opposite conclusion.[23] The model made no allowance for changes in clouds or convection, and erroneously indicated that 8 times as much CO2 would only cause 2コC of warming.[24]"
(the [] are the Wikipedia refs)
That paper even at the time was not well accepted in the climate modelling community. It still gets bandied about. So basically it was not a good paper then and certainly now should not be used to make decisions on climate change.
Mike
/ Global Warming? #635
Summer temperature variability may increase mortality risk for elderly with chronic disease
Posted: 09 Apr 2012 01:45 PM PDT
Seemingly small changes in summer temperature swings -- as little as 1ーC more than usual -- may shorten life expectancy for elderly people with chronic medical conditions, and could result in thousands of additional deaths each year, new research suggests.
/ Global Warming? #637
From Global Temperature Trends Since 2500 B.C.
By the end of this 21st Century, a big cool down may occur that could ultimately lead to expanding glaciers worldwide, even in the mid-latitudes. We could possibly see even a new Great Ice Age. Based on long-term climatic data, these major ice ages have recurred about every 11,500 years. Well, you guessed it. The last extensive ice age was approximately 11,500 years ago, so we may be due. Again, only time will tell.
I don't think I would believe anything those two authors say if they believe that. The Earth has experienced at least five major ice ages in its 4.57 billion year history: the Huronian glaciation (2.4 to 2.1 billion years ago), the Sturtian/Marinoan glaciation (710 to 640 mya), the Andean-Saharan glaciation (460 to 430 mya), the Karoo Ice Age (350 to 260 mya) and the most recent Ice Age, which is currently ongoing (40 to 0 mya). The definition of an Ice Age is a long-term drop in global temperatures from the historical norm, accompanied by an extension of continental ice sheets. Most of the time, the Earth is not in an Ice Age, and the average global temperature is about 22 °C (71 °F). Right now the average global temperature is around 14.5 °C or 58 °F.
/ Global Warming? #638
If I were going to pick a "straw man" to discredit I'd pick an easy one, say a Luddite or someone who thought the only "elements" were air, water, fire, earth, and maybe phlogiston.
Scientists are scientists when they are following the scientific method which typically is when they are researching and publishing in their area of expertise. It is not very notable to say that scientists make statements which fall outside those bounds.
When a baby doctor (Spock) gets an Olympic rowing medal the glory is not reduced because he is "out of his element" as apparently he was qualified in that field. When he involved himself in the Viet Nam war protest movement he was far afield from his training and books of baby psychology fostering permissiveness and instant gratification.
As an intelligent analyst you must consider your sources and modulate your weighting criteria depending on the attributes of the individual sources and applicability of their expertise. It is not helpful in trying to foster understanding to select a narrow source, highly refuted and discredited (one with a major contributor who has recanted his position) and brandish it like a sword collected from the vanquished.
Pat
/ Global Warming? #639
What triggers a mass extinction? Habitat loss and tropical cooling were once to blame
Posted: 10 Apr 2012 11:59 AM PDT (Science Daily)
The second-largest mass extinction in Earth's history coincided with a short but intense ice age. Although it has long been agreed that the so-called Late Ordovician mass extinction was related to climate change, exactly how the change produced the extinction has not been known. Now, scientists have determined that the majority of extinctions were caused by habitat loss due to falling sea levels and cooling of the tropical oceans.
Impact of climate change on forest diseases assessed
Posted: 10 Apr 2012 06:36 AM PDT
Climate change is projected to have far-reaching environmental impacts both domestically and abroad. A recently published report examines the impact of climate change on forest diseases and how these pathogens will ultimately affect forest ecosystems in the Western United States and Canada.
U.S. records warmest March; more than 15,000 warm temperature records broken
Posted: 10 Apr 2012 08:40 AM PDT
Record and near-record breaking temperatures dominated the eastern two-thirds of the United States and contributed to the warmest March on record for the contiguous United States, a record that dates back to 1895. More than 15,000 warm temperature records were broken during the month.
Pat
/ Global Warming? #640
phlogiston.
I like that term. It can cover so many facts in just one word. Makes life much simpler for me!:thumbsup:
Status
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
GATOR UTV (A63276)
GATOR UTV (A63276)
John Deere 825I (A64127)
John Deere 825I...
