Global Warming?
Status
Not open for further replies.
/ Global Warming? #601
This is an example of extreme weather as precipitation. It seems as though your making a correlation to temperature?
Bad example...try to find examples of low temperature extremes.
It is not the extremes one is concerned with it is the average.
Consider that organized weather observations and compilation has been around one-hundred and fifty years. The standardization of measuring devices (thermometers, barometers, hygrometers, etc..), occurred about the same time. Any weather observation or record taken before the 1940's is of dubious accuracy. Not all recording stations were equipped with calibrated devices. Other contributing factors are locations of measurements taken. Most current Official observations are taken at an airport. Many cities had no official recording station till airports became common.
/ Global Warming? #603
/ Global Warming? #604
I wonder what folks who live in low lying coastal regions (disproportionate percentage of the wealth in real estate) think about the melting ice and the downside possibilities of ocean levels rising?
On the other hand, folks who live a little higher up and farther from the beach could see their holdings appreciate significantly for a while at least.
Pat ;)
Even the so-called scientists say that it would take hundreds of years to melt the Antarctic Ice sheet. The same scientist postulate the increased ocean warming will actually increase precipitation over the continent. Melting of the pack ice shelves would create no significant rise in ocean levels.
Yes the oceans will change. Again. Nothing that is happening now is new. It's only a concern now because people are involved. If one thinks that the world is a stable platform, all they have to do is look at the great disasters in history. Tsunamis are older than recorded history. Earthquakes, Volcanic winters year round for two to three years.
Mankind should adapt instead of trying to change anything. All it would take is a Krakatoa or Pinatubo to lower the earths temperature by 3 degrees. Then you would have a mad scramble for food crops.
/ Global Warming? #607
The interesting thing is that many of us will live long enough to absolutely have proof positive of manmade global climate change. Even Limpbaugh and Hannity who will then both claim they told us so.
/ Global Warming? #608
For 20 thousand years the sea levels have risen with a few bumps here and there. The bumps were "little ice ages".
For the last 8 thousand years the ocean levels has been more or less steady.
This tells me that the earths atmosphere is not stable. It never has been, it never will be.
/ Global Warming? #609
In your mind what would be proof of man-made global warming?
Oh. And you can't mention any weather event or temperature extreme that has happened previously.
/ Global Warming? #610
The Coastal sea ice is mostly new ice each year. That ice is composed of salt water. There is an addition of precipitation which is fresh water in the form of Snow and ice crystals. The Fresh water glaciers that move from the Arctic Continent down to the sea can travel many miles from their deposit location mixing and churning as it moves.
Almost missed this one. The actual Glacier Ice does not mix and churn. It flows as a continuous mass.
But surely does mix, churn and bulldoze the strata's it travels over. Just think of all the lateral and terminal moraine or float deposited along the glaciers path.:)
The shelf ice is probably made up of mostly fresh glacier melt water that is of lower density than the seawater and will freeze at higher temperatures than saline seawater. All that cold fresh meltwater may also muck up the normal current flows and when that happens th Merry Breezes may be angered into deviant behaviour.:)
/ Global Warming? #611
If you have ever seen a glacier the streaks in the ice are sections of the flow traveling at different speeds. The center of the flow travels fastest. The uneven travel speed creates crevasses. Opening and closing at different travel speeds.
The meltwater is minimal in the Antarctic, only occurring in small areas along the coast. The pack ice is seawater that gradually loses most of the salinity during the freezing cycle.. Your right about the aberrant ocean current. The currents coming into the coastal areas melt large areas of the ice every year. Wind has an affect on the ice movement.
/ Global Warming? #612
The interesting thing is that many of us will live long enough to absolutely have proof positive of manmade global climate change. ......
That's about as erroneous a statement as could be made. While it's possible that might happen it is by no means assured that it will happen.
/ Global Warming? #613
I'll can tell you the way it's going, with 'first hand' knowledge, and that is for the last four years Canadian scientists have been forbidden from talking about anything related to climate change. Every paper, every press release, every email is censored at the source.
Agenda... you betcha.
That's interesting regardless of any other point here. That would be a good thread..pursuing that censorship and those who censor.
/ Global Warming? #614
If you don't like those guys, stop listening to them.
/ Global Warming? #615
Actually, sir, you are not correct when you say, "that ice is composed of salt water." Au contraire, mon ami... If you melt some of that ice the water is almost pure! It is NOT composed OF salt water. It was made FROM salt water and that is NOT the same thing.
As the ocean water begins to freeze, small needle-like ice crystals called frazil form. These crystals are typically 3 to 4 millimeters in diameter. Because salt doesn't freeze, the crystals expel salt into the water, and frazil crystals consist of nearly pure fresh water.
I was on Viet Nam GI bill when I took 14 upper division semester hours of physical oceanography in the physics department at San Diego State University so consider the above mini-tutorial as yet another federal tax rebate. ;)
It has been years since I had an opportunity to dredge up those old memories. Thanks... ;)
Oh, if anyone want some interesting reading (real science not hyperbole) then http://nsidc.org/icelights/
Pat
/ Global Warming? #616
We had an emeritus scientist with 40+ years of service, escorted out of the building by security when he was critical of a new policy. He didn't go public, he kept it within the organisation. Boom out the door.
Contrary to what most people think, these guys work for the love of the science, do not receive royalties or any other benefits, in some of the most difficult environments on the planet.
So bad now, that policy writers and lawyers outnumber the actual people doing the science.
Case in point. We had a 5.0 earthquake in June of 2010. A big deal here as we have a lot of unstable clays in the ground. It took 6 hours for the Federal department in charge of emergency response to issue a statement because no one was allowed to talk directly to the press. It all had to go through the lawyers hands first. The USGS had information within minutes of the event.
/ Global Warming? #617
Manmade? Well, that is always going to be in doubt in the minds of a few until we quit dumping CO2 into the atmosphere and then see a temperature decline. That won't happen. But climate change. How about the Gulf Stream quits flowing?
/ Global Warming? #618
Not knowing the facts of the matter, I can only speculate...
Escorting an emeritus researcher out of a meeting sounds like it could be a form of censorship. I can't know if his remarks were appropriate for the forum and to the matter addressed, but generally folks would offer considerable forbearance to an emeritus researcher.
The last part sounds like that department is in disarray and needs a general investigation as to efficacy and purpose. Most such departments know in advance who will be speaking and approximately what will be said for typical sets of events and circumstances. That dept. should be put under review. If the word of the technical authorities cannot be put out due to the legal folks, it calls into question the need for the unheard researchers.
Censorship is often misunderstood. I am not saying you are misunderstanding, or that your citations are not valid examples. But I am sure you have seen folks claim censorship in cases where there was no right to speak in any case. For example, I didn't have a right to make this post, and if it gets removed, I would not claim censorship.
My sensibilities may not be shared by most folks, but if a person is in a meeting complaining about a government policy, I want that person heard. Once heard...he can't filibuster...but we should always try to give opportunity to criticize policy which restricts others, or things which spend the people's tax dollars. In the case of a senior researcher, it would have been smart and appropriate to give him a fixed amount of time for his comments, and just go silent and let him speak his piece.
/ Global Warming? #619
Federal scientists in Canada are not allowed to speak to reporters without the consent of media relations officers of which we have 4,459 at last count. This is just a Conservative government policy to control all information from federally funded researchers. Harper's a control freak and doesn't want anything said that might contradict some political policy his party has, hence they muzzle all those he can. He'd like to muzzle everybody but he cant manage to do that...yet.
Ottawa ‘muzzling’ scientists, panel tells global research community - The Globe and Mail
Poppycock. In this case, it's pure and simply censorship for political purposes. The real question is why do we have 4,459 media relations officers. It wouldn't matter if it were 10 researchers, they would still be gagged.
/ Global Warming? #620
Poppycock. In this case, it's pure and simply censorship for political purposes. The real question is why do we have 4,459 media relations officers. It wouldn't matter if it were 10 researchers, they would still be gagged.[/quote]
I need to look up "poppycock" I have heard the term, but never seen the definition.
In this case, if the research is suppressed, is the research of use to the people who pay for it? Canadians must decide these issues...but to me...I want what I pay for, and if the lawyers doing the suppression are in the department whose findings are being suppressed, why can't the general lack of utility of the department be used as a wedge to either prop open the information window, or close down the department?
Edit:
poppycock...nonsense, meaningless chatter
Your current situation is nonsense...why pay folks to come up with things to say, and others to suppress it?
Status
(3) 3 1/2" X 36" HYD CYLINDERS (A64280)
(3) 3 1/2" X 36"...
UNUSED WOLVERINE SB66 - 66" ROCK BUCKET (A64281)
UNUSED WOLVERINE...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
(2) 380/85R28 TIRES W/ (10) LUG WHEELS (A64280)
(2) 380/85R28...
2014 Grand Caravan (A62679)
2014 Grand Caravan...
Unverferth 432 (A64119)
Unverferth 432...
