Global carrier
/ Global carrier #1
Swedona
5075M
My 540M loader with the global carrier will not latch after changing bucket to forks or back. When you curl the implement back the cam does not hit the linkage to reset the latch. Has any one else had this problem ? And what did you do to fix it?
/ Global carrier #2
You mean it won't latch at all or just won't latch without you manually doing it?
/ Global carrier
It needs to be manually latched. It’s like the latching cam is about a half inch from contacting the latching rod when the bucket/forks are curled back.
/ Global carrier #4
I haven't had that issue I don't think. Seems last time I changed over I may have had to trip mine by hand but I can't be sure. I will take note next time.
/ Global carrier
Thanks
/ Global carrier #6
You don't have dirt or debris between the bucket and loader frame that's holding it off?
/ Global carrier
It’s only has five hours on it. Not even been in the dirt yet.
/ Global carrier #9
You also need to lower the loader down to a certain hight. I have a H340 self leveling.
/ Global carrier #10
So did you figure the issue ?
will it latch curling it back without bucket or forks attached ?
2017 Toyota Tundra 4x4 Crew Cab Pickup Truck (A61573)
2017 Toyota Tundra...
2022 JOHN DEERE 26G EXCAVATOR (A64279)
2022 JOHN DEERE...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
2020 ISUZU W4500 4X2 S/A  16FT BOX TRUCK (A59912)
2020 ISUZU W4500...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
UNVERFERTH PERFECTA II 18' FIELD CULTIVATOR (A63291)
UNVERFERTH...
