dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,708
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
We had one for close to 18 yrs. Had to replace it once as some idiot (ahem...me) dropped a glass spice container on it from above and it broke the top. Other than that it was nice. Not bad to clean, but a razor scraper helps a lot with boil over mess. Any Soft Scrub type product is good for cleaning it, and then buff it out with a clean paper towel if you are the shiny surface type (rarely for us). There is glass cleaner stuff you can buy too, but it is basically Soft Scrub for more $$. They have limitations. The main one is they really don't heat up fast. Not bad, but they are basically an electric element as far as performance goes. They also tell you cookware should be flat on the bottom, so no warped pans. Never heard big issues with cast iron, as long as you don't do stupid things like superheat a pan then put it on a cold section of the top. Stuff like that goes without saying. It is tough stuff, but nothing is impervious. If you have a burr in your cast iron, 15 seconds with a file or some sandpaper should fix that and then no risk of scratching the surface. My wife used a bunch of cast iron on ours. Never an issue. The slow heating was probably the biggest annoyance. This is our experience. FWIW
