Oil & Fuel GL 3940 front axel oil change
   / GL 3940 front axel oil change #1
jem041279
Abbeville, La
2011 Kubota L3940 4x4 w/ FEL & John Deere 750
I have decided to go with gear oil in my front axel but not sure if I need to spend the extra money on synthetic oil or not. My feeling is regular 80w 90 gear oil would serve my purpose, please give me reasons that I should not go with that, btw I typically do not use 4wd if that makes any difference. Thanks
   / GL 3940 front axel oil change #2
I have a grand L 3130 and I changed my fluid to 80-90w I bought at tractor supply. I think mine took 5 quarts or so. Works for me.
   / GL 3940 front axel oil change #3
I would go with conventional oil, synthetic is like $18 a quart.
   / GL 3940 front axel oil change #4
I drained the HST oil and put regular dino 80w in. Even if you do not use 4wd much the gears still turn when the tractor moves. I'm a bit old school and just feel better about gear oil. Kubota says either will work. Be sure to drive around a bit and check the level again. The oil needs to get evenly distributed between the left and right side of the axle. :thumbsup:
   / GL 3940 front axel oil change #5
Do what the manual says to do.... :reading:
   / GL 3940 front axel oil change #6
I just did my L3540 and put synthetic in mine. Took less than 4 1/2 quarts.
   / GL 3940 front axel oil change #7
The polymer chains in synthetic give longer hang time; in a gear bath system there is not much advantage to that since it is always somewhat submerged.
Syns flow and lubricate better at temp extremes; I can have minus 30F in winter and 110 plus in the summer.
I use Mobil 1 syn gear oil in my L5740 front for those reasons, and I decided to use gear oil (instead of transhydo fluid) because I have a non-scientific thought that it might be better for the pressures involved in geared systems.
I am a tractor waxer, so I also use syn oil (Mobil 1), and syn THF (Chevron All Weather THF).
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
2005 Ford F-350 4x4 Service Truck with Crane, VIN # 1FDWX37P55EB97537 (A51572)
2005 Ford F-350...
2015 Ford Focus SE Sedan (A50324)
2015 Ford Focus SE...
Chevrolet C8500 Flat Bed with a Moffet Kit (A52748)
Chevrolet C8500...
2017 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2017 FREIGHTLINER...
1985 AM General M35A2C 2.5 Ton 6x6 Fire Rescue Truck (A50323)
1985 AM General...
