Oil & Fuel GL 3940 front axel oil change
   / GL 3940 front axel oil change #1
jem041279
Abbeville, La
2011 Kubota L3940 4x4 w/ FEL & John Deere 750
I have decided to go with gear oil in my front axel but not sure if I need to spend the extra money on synthetic oil or not. My feeling is regular 80w 90 gear oil would serve my purpose, please give me reasons that I should not go with that, btw I typically do not use 4wd if that makes any difference. Thanks
   / GL 3940 front axel oil change #2
I have a grand L 3130 and I changed my fluid to 80-90w I bought at tractor supply. I think mine took 5 quarts or so. Works for me.
   / GL 3940 front axel oil change #3
I would go with conventional oil, synthetic is like $18 a quart.
   / GL 3940 front axel oil change #4
I drained the HST oil and put regular dino 80w in. Even if you do not use 4wd much the gears still turn when the tractor moves. I'm a bit old school and just feel better about gear oil. Kubota says either will work. Be sure to drive around a bit and check the level again. The oil needs to get evenly distributed between the left and right side of the axle. :thumbsup:
   / GL 3940 front axel oil change #5
Do what the manual says to do.... :reading:
   / GL 3940 front axel oil change #6
I just did my L3540 and put synthetic in mine. Took less than 4 1/2 quarts.
   / GL 3940 front axel oil change #7
The polymer chains in synthetic give longer hang time; in a gear bath system there is not much advantage to that since it is always somewhat submerged.
Syns flow and lubricate better at temp extremes; I can have minus 30F in winter and 110 plus in the summer.
I use Mobil 1 syn gear oil in my L5740 front for those reasons, and I decided to use gear oil (instead of transhydo fluid) because I have a non-scientific thought that it might be better for the pressures involved in geared systems.
I am a tractor waxer, so I also use syn oil (Mobil 1), and syn THF (Chevron All Weather THF).
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
197711 (A51244)
197711 (A51244)
2014 Nissan Frontier Ext.Cab Pickup Truck (A50323)
2014 Nissan...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2018 INTERNATIONAL MA025 (A52472)
2018 INTERNATIONAL...
