GFCI problem
   / GFCI problem #31
There is a reason some outlets/switches sell for a few bucks vs. the bargain basement stuff. Good luck with your heater pad idea. The internal heaters suck a lot of juice, will goof with your AM radio signal and are prone to leaks that will trip a GFCI. My wife tried 3 stock tank heaters on her fish pond and finally gave up and bought one made for fish ponds.
It is a purpose built unit that has a pad heater on the bottom and insulation all around the bowl, you put a 12" piece of pipe into the ground to bring up the heat from under the frost layer so it doesn't have to work as hard and it keeps the valve thawed.
Aaron Z
   / GFCI problem #32
Aaron Z
Ok...so water can get in but what happens then? Doesn't it freeze?
   / GFCI problem #33
They are insulated so that they don't freeze (letting heat come up from below the frost line) and can have a heater underneath. Here is the installation video for one we are looking at:
The one we are looking at also has a heat pad on the bottom of the tank.
Aaron Z
2015 Ram 1500 Crew Cab Pickup Truck (A48081)
2015 Ram 1500 Crew...
Honda Pioneer 1000 UTV (A50860)
Honda Pioneer 1000...
2025 JMR 40in Grapple Rake Mini Skid Steer Attachment (A49346)
2025 JMR 40in...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
2014 Dodge Charger Sedan (A48082)
2014 Dodge Charger...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A50397)
NEW 2024 LOAD...
