Getting the old girl going
   / Getting the old girl going #11
yes.. a fram c159 is a napa 7011 but a c159 is a lil cheaper.. about 4$ cheaper than a 16$ 7011
   / Getting the old girl going #12
A word to the wise on the mag. The cover with the 2 screws is the cap. You would find the rotor under this. The main cap assembly is held on by 4 screws. This is where the points, condenser, and coil are found. On removal of this cap, it is likely to throw the ignition timing off. ( rotor is driven by a fiber gear) Set the engine just before #1 ( #4 exchaust valve just closing) remove the cap, and make sure the rotor faces before#1. Also, it's far easier to work on mag out of the tractor. On the oil filter, the oem filter from Allis had a wood dowel installed to keep the fiber of the filter in place. The only filter that has kept this was the Baldwin filter. Allis had oil pressure issues, years ago, with filters being shipped without the dowel. I may still have service bulletin on it from the company.
   / Getting the old girl going #13
biggest oil filter / pressure issue was when some oems went to paper pleted filters instead of the filter floss.
napa even had this issue.. fram, at the time was the only one I could find with floss filters. since then, napa figured it out and made a compatible floss filter. ( well.. not napa.. but their suppliers.. mostly wix..e tc.. )
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
Case 870 Agri King Loader Tractor (A59814)
Case 870 Agri King...
CAT 930M (A58214)
CAT 930M (A58214)
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
