Getting ready to install clutch
/ Getting ready to install clutch #1
LGP
OK the clutch is gone and I have to split the S630D in half.
First any suggestion were I can get this rebuilt and approx. cost.
Second are there any little tricks that I should know before I jump into this. I have manualls.
This is something that I have never done and I am not look forward to this but it has to be done.
/forums/images/graemlins/confused.gif
Your help is appricated
Larry P
/ Getting ready to install clutch #2
I can't help you much on your split. But here is what I did with my old Ford 8N split. Most tractors would be split the same way I believe. I used a jack stand under the tranny area with blocks and a few tapered wood shingles to get the proper height. Then a floor jack to support the backend of the motor and pulled it apart. I don't know if you can get a rebuilt clutch for your tractor. Do a www.google.com search for tractor parts or consult with your local dealer.
/ Getting ready to install clutch #3
I may have to split my Mits. 1450. Make sure you drive some wedges between the front axle and the frame on both sides. Otherwise the front will tilt over when you split the tractor. I think you block up the front half then put a floor jack under the rear for support and then you can roll the rear end back. Parts can be found, maybe locally at NAPA. I have bought some things there. If not check the mitsu club at yahoo. Bill Rogers or Len Shaefer can get what you need. If there is a rebuilder close by it will be a lot cheaper on the clutch disk. It don't hurt to ask. Don't put it back together without replacing the release bearing.
/ Getting ready to install clutch #4
I can supply a rebuilt clutch and pressure plate as well as the other parts you'll need. What you are attempting is not difficult if you take your time. But make sure the tractor halves are secure at all times. Its obvious, but bears repeating, you're dealing with very heavy parts. Be careful and have help nearby. Call 800-609-5110. Bill Rodgers - satohparts.com
2R FIELD CULTIVATOR, 3PT (A64280)
2R FIELD...
2018 CATERPILLAR 232D SKID STEER (A64279)
2018 CATERPILLAR...
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
