Getting ready for Winter?
/ Getting ready for Winter? #21
NY_Yankees_Fan said:
Power window motor works great, cheap too about $25. I added it last year, nice, also added a motor to the chute deflector, about $75.
Do a search you will find info on both of these projects.
And oh yea where is your cab? :D
Thanks for the tip. I will look into that. My cab is in my dreams...Having a cab would be great for sure. Someday...
ewoz said:
Hey kevin,
What is the model number of your snowblower? I have a BS2750B that I run on my BX2230. I wish it had hydraulic chute rotation like yours has. I am thinking of adding that feature to mine and would like to get some ideas.
My blower is an L2052 but the hydraulic rotation may have been an option. I'm not sure since I bought it used.
Kevin
/ Getting ready for Winter? #24
kevinj said:
I assume you meant this to me?? It is a 2750 from my BX1500. The chute rotator is a Kubota unit I added when I got the BX1850.
Yes I did mean you. I got my Kevin's mixed up. I guess a 2750 is different from the BX2750 that I have. Kubota has an electric rotator for my model. The dealer did not recomend it. Thanks for the reply.
/ Getting ready for Winter? #25
Kevin
Thanks Kevin. I'll see what i can learn about the L2052.
/ Getting ready for Winter? #26
Dusty,
See this link look at the last page.
I had the heater outlet tapped above the thermostat so I have to get the tractor warm to get any heat. In the picture they taped it below the thermostat. I just cover half the radiator screen with plastic and it runs fine.
http://www.cabdepot.com/images/sales_docs/2000454_kub_bx_2200_std_cab.pdf
Thanks for that information. I intend to tap in below the thermostat housing, and I wanted to return to the block if possible. What surprises me is that they are returning the coolant to the top radiator hose. Usually it goes back to either the block or the lower hose. The top hose is the pressure side of the water pump and the bottom side is the suction side.
/ Getting ready for Winter? #27
ewoz said:
Yes I did mean you. I got my Kevin's mixed up. I guess a 2750 is different from the BX2750 that I have. Kubota has an electric rotator for my model. The dealer did not recommend it. Thanks for the reply.
Mine IS a BX2750 blower. I had a hand crank the past 3 winters and it was fine but the new handle bearing for the 50 series is a joke and I did not want electric on the rotator so now that Kubota has the hydraulic kit I opted for that. It is a bit pricey but so is my time to source everything to rig something up. The kit has a heavy ring and pinion gear. The wire worm would not take the stress of a hydraulic motor very long.
/ Getting ready for Winter? #28
Could you please post some pictures of the new ring and pinion hydraulic set up? Thanks
/ Getting ready for Winter? #29
I hope the detail is ok. All the parts are black.
/ Getting ready for Winter? #30
That looks pretty slick. Have you used it yet? My neighbor has a John Deere tractor with a blower. His rotator has a linear hydraulic cylinder that tugs back and forth on a cable that wraps around the chute. A very clever setup. If I were a clever person I would figure out how to rig a similiar setup on my machine.
/ Getting ready for Winter? #31
EW,
I have also used an electric window motor to turn the chute, about a $25 investment in parts, works great!
Here is a link on how it was done, 2nd pagehttp://www.tractorbynet.com/forums/kubota-owning-operating/51158-bx2230-curtis-cab-snow-blower.html
Here is a link for an electric acuator to move the chute up an down. I picked up the acuator off e-bay. Make sure you get one with automatic stop at full length or you will burn the unit out. Cost was $75 and drilled 2 holes and a switch, works fine.
http://www.tractorbynet.com/forums/kubota-owning-operating/50418-bx2230-bx2750-electric-deflector-wiring.html?highlight=actuator
/ Getting ready for Winter? #32
I wonder how they keep the unit from self destructing when it reaches the end of the gears on the chute. I know from experience that the gears don't go all the way around the chute, so you can't blow snow back in your face. I had to cut additional gear teeth in mine to keep from breaking the wire spiral gear. Now if I go too far, the windshield gets a load of snow dumped on it, but I haven't broken any more gears.:D
Dusty
/ Getting ready for Winter? #33
Not yet other than to test it. It seems to work well.
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
11" QUICK ATTACH EXCAVATOR BUCKET (A60429)
11" QUICK ATTACH...
2013 Bush Hog 296 6ft. Rotary Brush Cutter Tractor Attachment (A61572)
2013 Bush Hog 296...
KMC 3pt 6 Row Vine Lifter (A64119)
KMC 3pt 6 Row Vine...
2004 Lincoln Navigator SUV (A61574)
2004 Lincoln...
