Getting parts - how quickly?
/ Getting parts - how quickly? #1
cgraham
S. Central NM
Kioti LB1914
Is there a good parts inventory in this country? I may be looking at a new cylinder sleeve, and I'm wondering how long I should expect to wait for it. I have to plan my work around the delay, when known.
What has your experience been with major parts?
Thanks, Charlie
/ Getting parts - how quickly? #2
Give your dealer a call and have them check if they have the part in stock in North Carolina.
If they don't have it there, it will be a long lead item from Korea.
I've only gotten blades for a deck and some simple hardware that was in stock, nothing exotic. In the case of the stocked stuff, worst case of two days for the parts to show up at my dealer in their standard parts order from North Carolina.
Best of luck.
/ Getting parts - how quickly? #3
It can take a LONG time if the part is not in current american stock. Very very long. It's like they need to accumulate enough backordered parts to fill a container before shipping to america.
Regular parts, in stock anywhere int he country can be a couple days.
Thanks, folks: if I need the hydraulic cylinder sleeve, it looks like it might be a long wait. I'll call the dealer on Monday. I'm exploring a repair (stripped fitting welded on).
Charlie.
/ Getting parts - how quickly? #5
Any pics? At first I thought you were talking about an engine sleeve, then your last post says Hydraulic cylinder sleeve. You might be better off just getting a replacement cylinder from Tractor supply, if in fact that's what your talking about.
/ Getting parts - how quickly? #6
What part do you need???
Not sure what a you mean by a Hydraulic Cylinder Sleeve.
BTI
BTDT: sorry for the lack of clarity. The photo in the next post shows the cylindrical sleeve of the bucket curl hydraulic assembly. Thanks for the Tractor supply hint.
BTI: thanks for asking.
I MAY need a bucket cylinder outer sleeve, because one of the hose fittings welded to it is stripped. I hope to be able to replace the fitting, and am still researching what it will take to repair it. In case everything else fails I thought it would be wise to know availability in country, and for this and other parts approximately how long it would take to obtain if not in country.
Charlie
Here is the photo
/ Getting parts - how quickly? #9
I would take it off and take it to a reputable cylinder shop.
They should be able to fix you right up.
BTI
/ Getting parts - how quickly? #10
Like BTI said, take it to a hydraulic shop. They will fix it for very little compared to what the dealer will want for a new cylinder and it will be a lot quicker turn around.
/ Getting parts - how quickly? #11
Figure any machine shop could do the job, we have done it many times when cutting cylinders down for some applications, a cylinder shop could do it easily
/ Getting parts - how quickly? #12
They don't airfrieght stuff? We can get parts from Kubota's Japaneese warehouses in 3-4 days?
/ Getting parts - how quickly? #13
This isn't a Kubota, JD, or husaberg. I have had items sit on "backorder" for months.
/ Getting parts - how quickly? #14
Makes you proud to be a member of the "pack", doesn't it:eek: I wish I had done a little more research before I purchased:rolleyes:
/ Getting parts - how quickly? #15
It's an inconvenience that may or may not be temporary. Kioti has large warehouses and once they figure out which parts to keep stocked then maybe the "backorder" problem will go away.
I'm still proud to be a part of the pack and the parts availability issue has not become critical. Good dealers might even borrow a part from a yard tractor to keep you moving.
Neil just likes to point out that Kubota still does a couple of things better. He tries to keep us honest.
/ Getting parts - how quickly? #16
My dealer did just that last summer when I mysteriously bent the dipperstick cylinder rod into an "L" shape while pulling some small Poplar stumps:confused: As I mentioned in an earlier post, I'm not dissing the dealer;he has just so many resources, but the manufacturor seems not to care after the sale.
/ Getting parts - how quickly? #18
Kioti had a very good parts system when I first started.
They went thru alot of changes the next few years.
In the last year I have had no parts backordered except one just last week.
The parts are arriving right behind the others.
Thats pretty good.
I agree in the past they had some issues, this isn't the case now.
I'm sure stuff will get backordered even now......it happens with all of them.
I know some brands have a system that they can tie into and grab parts from other dealers in the company is out of stock.
This helps immensely.
I'm sure Kioti will have this down the road.
BTI
/ Getting parts - how quickly? #19
Patches: The Bent Dipperstick cylinder rod can happen to any of them.
Check out some of the other boards and do a on it search.
It happens when the stick is pulled close against the hoe.
Usually seems to happen when doing small stuff, from what I've read.
BTI
/ Getting parts - how quickly? #20
BTI; Thanks for the tip; I had no idea how I managed to mangle that rod working no harder than I was. I was watching the bucket, which was bound-up in the hole among the roots, and when I finally extracted it: Voila. Your explaination makes sense to me:D
CASE INTERNATIONAL 2020 - 25' FLEX HEADER (A63291)
CASE INTERNATIONAL...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63689)
Greenworks...
(2) 15 Gallon Sprayers, 25 Gallon Sprayer, Honda Pressure Washer, Wheel Barrel (A64119)
(2) 15 Gallon...
Caterpillar Warranty Guides (A63117)
Caterpillar...
