Getting my first fence installed, quick question
   / Getting my first fence installed, quick question #11
-- you could just squeak by with 1 gallon if you can get 400 square feet of coverage.
If it was a flat surface a gallon might do it, but when spraying round posts there will be a LOT of waste.
   / Getting my first fence installed, quick question #12
Agreed. And I seem to use more paint when I am spraying flat surfaces than when I am using a roller or brush. But I'm a pretty sorry painter.
Steve
   / Getting my first fence installed, quick question #13
2 coats of Sikkens and you won't have to touch them again for many years. They'll be really pretty too. Ain't cheap though, $60/gallon, but I'm a believer in getting what you pay for. Should take about a gallon each time, which works well because you can put the base type Sikkens on and then the finish type Sikkens. It's actually sold as a 2 step process (or 3 if you want to overkill it). Stuff is thick and lasts. Gives the look of a clear wood bar top with the real thick epoxy poured on it.
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
