Getting more HP from TC24DA
   / Getting more HP from TC24DA #31
Now, I'm all for turbos - but with it comes the need for an intercooler. Also, non-turbo engines typically run higher compression ratings, because you don't want to get to much heat in the cylinder. The timing for turbo'd machines is also different - so, whatever you decide, have an experience DIESEL mechanic do it. Seems simple - just change your manifold and slap on a turbo, but there's quite a bit more to it. Blowing an engine apart with 60 lbs of boost probably wouldn't get you the power you want :)
2011 JOHN DEERE 329DT SKID STEER (A51242)
2011 JOHN DEERE...
2016 CROWN RR5210-35 FORKLIFT (A51222)
2016 CROWN...
2005 GEHL CTL70 TURBO SKID STEER (A51242)
2005 GEHL CTL70...
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2012 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2012 STEPHENS...
