Getting hay balers ready
   / Getting hay balers ready #32
Thanks for numbering them because it’s really hard to count that high 🤣
When are you cutting? Just finished getting what’s left of first cut in the barn, sold a shocking amount straight out of the field. It was a great hay year last year here but everyone ran out this spring.
   / Getting hay balers ready #33
6 is even worse. Better you than me.
Small square balers are amazing to me. Some guy with no computer modeling, or computer for that matter, figured out that complex machine and got it moving. Like I was telling the land owner yesterday when he was watching me grease and get ready to roll, there’s nothing but very simple mechanisms inside…the problem is there’s about 100 of them and they just all work in perfect synchronization or they won’t work at all.
I did it for someone else ;)
I wait longer for tonnage. I get paid by the ton.
I am probably going to start in ~10 days. I’m also a lot further north.
2nd cutting I will go in a little early in some of the fields I drill and get some feed hay stored away.
   / Getting hay balers ready #35
Me, I'm ready to go but alas, I have no tractor. It needs to get delivered from the dealer. Been there for a tune up.
   / Getting hay balers ready #36
Well now it’s back to the Hesston up 10’ in the are and workin on those dirty, stinkin‘, rotten knotters. :giggle:
1st knotter on left had 2 leaky oil lines last summer and made a bin mess. All my manual pumpers leak a little, but not enough to replace.
Big mess, but not to worry-Hay Dude to the rescue.
One of the 90* brass oil fittings snapped clean off when I removes it. Easy to remove the threaded shaft since its oiled and soft brass.
Back over to the 270 Magnum.
Got everything hooked back up and for now, no leaks. :cool:
Please get a shield for that PTO. Complete Aftermarket Walterscheid plastic shields are available from multiple sources for less than $100.
Sure “doctor”.
Since its so cheap, you buyin?
   / Getting hay balers ready #38
I thought you had previously stated that you & your Kubota dealership owner were "Good Friends"?
   / Getting hay balers ready #39
We are. In fact I work there part time but like with everything else, they are busy and I get to wait just like the next guy. I suspect if it wasn't for the Kubota 0 percent financing program, they wouldn't be.
Been spending a lot of time helping assembling units lately. It's done and ready to come to the farm. Problem is, it will have to be physically driven here as the new bailer is to large (high and wide) to put on the roll back with the tractor attached to it.
Their Cub Cadet mowers business is booming too, interestingly. Lots of cubs in the shop for various repairs, mostly electrical issues and poor maintenance on the part of the owners. People tend to not do routing maintenance on their lawnmowers, just put them away in the fall and expect them to run without issues come spring. Don't play that way with the gum gas we now have.
   / Getting hay balers ready #40
Sure “doctor”.
I bet Agri-Supply is less that the HayDr. In as much as you are running it and you seem to be pretty conscientious, I don't see you getting tangled up in it anyway.
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
1992 CATERPILLAR 14G MOTORGRADER (A52709)
1992 CATERPILLAR...
JOHNSON SEAHORSE OUTBOARD MOTOR (A58374)
JOHNSON SEAHORSE...
2003 Volvo L60E Wheel Loader w/ 3 in 1 Bucket (A59213)
2003 Volvo L60E...
