Getting clay mud off tires easily
   / Getting clay mud off tires easily #41
I heard there were a lot of guys looking for work. Give the new guy the toothbrush.
Them meth heads can get it done in a jiffy.
   / Getting clay mud off tires easily #42
I built a trail on a step side hill above the lake just to work around driving the x and the skid up the drive way. There is not a good way that I know of, pressure washer works fine if it is warm enough, and you have a place for the pool to drain. Do the work as fast as you can, and fix it once when you are done?
Best,
ed
   / Getting clay mud off tires easily #44
What is a solution for sticky, clay-mud build-up on tractor tires and skid steer tracks when I get back at the shop? From Oct-Mar it doesn't take much for the sticky clay to create a 1-2" layer all the way around the tires/tracks.
Short of pressure washing before going inside, is there a labor-saving way to get the bulk of that mud off before going indoors or near the shop.
Is there some type of "cattle-guard" that you could drive over that would get it off?
How about some sort of tire-scraping wheel or track attachment?
Maybe something you can put on the tire as a non-stick treatment?
Something else?
Thanks, Scott
I smack the tires with a piece of wood (think baseball bat or short 2x4) on the sidewalls and treads. The rubber deflects and pops the clay off. Drive the tractor forward a few feet and do it again. This work great on my turf tires after rototilling.
   / Getting clay mud off tires easily #45
Another vote for pressure washing.
   / Getting clay mud off tires easily #46
Something else?
Thanks, Scott
I have a 1/4 mile stretch of paved road near my place. When my tires get caked with mud I put the traactor in high gear and run it up and down the road. The mud flies off.
   / Getting clay mud off tires easily #47
Let dry, then drive around.
   / Getting clay mud off tires easily #48
Pack the mud with M80's, and a long, fast acting sequential fuse,, light, and stand back.
If you do it at night, at least this will bring some fun to your life,,, :oops:
   / Getting clay mud off tires easily #50
Tell that to the construction guys building the new housing addition across the road from me……
2013 Peterbilt 367 20Yd Ox Bodies Tri-Axle Dump Truck (A56858)
2013 Peterbilt 367...
2016 Komatsu PC240 LC-11 Excavator (A59213)
2016 Komatsu PC240...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
T/A Flatbed Trailer (A59230)
T/A Flatbed...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58216)
30 INCH TOOTHLESS...
